Dang that REDARC looks beefy. I got a CTEK D250S but if it doesn’t work out, I may have to look into one of those.
Ya. That's always an option. Right now I simply press a link button next to my driver's seat.
First world problem for sure...but I'd prefer to retain that. Bottom line, though, is I need a better charge solution for my dual AGMs. The fuse resistor solution does help, but still doesn't quite top things off as well as a Redarc or similar.
The mulitiple, patented, charging profiles seem pretty outstanding in the Redarc unit, from reading at least. Even with the diode you're not getting proper charge to the AGMs (especially with a LiFePO4).
Well the shower is a semi-bust. I need a larger heat exchanger. The water gets a little warmer but not hot. Good enough for a shower, just not a comfy one. I went with a 10 plate, I'll swap it out for a 20 plate.
Any better if you turn your heat on inside the vehicle?
Nope. The exchanger itself gets very hot, it just gets overpowered by the water as opposed to the water getting overpowered by the coolant. The shower water is nice a toasty for a few seconds then cools down. I'm going to swap the hot coolant feed to another source tomorrow but I doubt it'll change much.
Stupid LBJ, democrat, tree-hugger tech.
How are you liking the Redarc setup? Looks to potentially be a better option than a traditional dual battery setup.
