The RCTIP for the LT285/55R20 Geolandars on your 2014 LX570 is 43psi F/R.
HTH
Thank you kindly sir. They were all at 37psi. I'll find my air compressor and make the adjustment.
HTH
I searched and found a couple of pressure recommendations in that size but they all have a common theme: not enough information given. So what do you have? LT, P, or ISO metric?275/60/20 KO2 on 2010 LX570? I looked but didn't see that in the thread.
Probably because KO2's are not made in that size![]()
Thanks!
I’m a real novice when it comes to this. I appreciate the help!
@gaijin - can you clear up this question I have on Michelin Defender LTX M/S 275/65/18 116T (P-metric) for a stock 2013 Land Cruiser?
Maybe I am missing something (like they aren't the same tire or something like that) - but in this post you say 38psi
Tire Pressure recommendation
Gaijin thanks for the service you have provided. Include me in the group that would be lost without you. I have a question. Why do some cars have a different F/R tire inflation number on the door sticker?forum.ih8mud.com
And in this post you say 33psi
Correct, I just purchased a set of 275/65/R18 Michelin Defender LTX M/S 116T SL. The guy at Discount said to not go P-metric and go to LT. So I did. I guess I never really considered the PSI needing to change based on the type of tire...So when I read before that you mentioned it’d be at 45PSI...forum.ih8mud.com
Thanks for all your information on this forum - it is greatly appreciated
@gaijin - New to forum - could you please provide RCTIP for 2020 LC Heritage with Nitto Ridge Grapplers LT275/70R/18 - Sorry for any mistakes made in posting
Thank You
hello gaijin, i just bought a 2018 200 series Land Cruiser. The previous owner must have put on new wheels and tires while he or she owned it. They are no longer the stock 18” rims. Now the tires are Micheline Defender Michelin LTX M/S 275/55R20. Would you please tell me what cold pressure i should have these at? With two people Two ARB drawers, and a 75L Dometic Fridge in it?
And how much pressure do i add if i add 400lbs of food, drink and camping gear (for the highway).
thank you!
Hi,
Running a stock 2020 LC200 V8 Diesel with 275/70r17 KO2 LT 121/118r E
Not sure if any different from Petrol V8 in terms of weight/pressure? Is it the recommended pressure still 40psi?
Got it, thanks!
The RCTIP (Recommended Cold Tire Inflation Pressure) for the LT275/70R17 E KO2 tires on your LC200 is 45psi F/R.
HTH
