Great repository of information. Any thoughts on pressures for these new shoes?
2015 LX 285/60/18 Toyo AT2?
Thanks
Thanks
Thanks
Just wondering how important the outside temperature differential convey to tire pressure my understanding is that your tire pressure normally goes down by one psi for every 10° change in temperature either up or down so my question if you live in Florida you aired up to 45 pounds when it’s 60° out yeah had up north when it’s 30° out this a big deal should you be concerned? When the tires get warmed up on the road the temperature reading goes back up to 45 range
can i get recommended tire pressure pressure for nokian hakka r3 suv 285/60/18 on my 15LC
Thanks
Thank you in advance for sharing your experience and knowledge with us all.
I am very curious to know your recommendations for my 2 tire setups for my 2008 LX 570.
1. Trd rock warriors with 285/70 R17 Milestar Patagonia MTs (Load range E). I’m currently running these at 40psi on the street.
2. Stock wheels with 275/60 R20 KO2s (Load range D). Running these at 36psi.
Thanks!
Oh great tire god Gaijin I need your assistance again as it’s winter if you don’t mind. Looking for cold pressure for a 285/70R17 Nokian Hakkapellita LT2 WITH a landcruiser that has a driving around weight of 7400lbs. (7385 for discussion purposes)
Thanks as always buddy! You’re a huge help on the forum.
I searched the thread and haven't seen the correct cold tire pressure recommendation for these yet so I thought I would ask.
Falken Wildpeak A/TW3 LT285/60/20
Thanks in advanced..
Hey @gaijin
I really appreciate all your info here.
I'm running the Kumho Crugen HT51 in LT275/70r18 (load E rating, 125/122R)
I've been at 41psi driving from sea level to 6200' in the winters, and wanted to confirm this is correct. Thanks.
Gaijin, Lord of Rubber. If you would be so kind as to supply me with the appropriate tire pressure for a 2011 LC200 with Cooper Discovery ST MAXX tires in LT285/65/R18 Load Range E.
I am in your debt.
I had to search to find that you are running these on a 2009 LX570 ...
The Recommended Cold Tire Inflation Pressure for the LT285/60R20E 125/122R Wildpeak A/T3W tires on your 2009 LX570 is 38psi F/R.
HTH
Could someone help with the appropriate tire pressure for a 2008 LX200 with 275/60/20 Falken Wild Peak AT3?
