Build Time for LS swap...
Lol. Try the same but on 40's:) I have been hovering around the v8 swap threads and making noted but yet to pull the trigger. I'm want an atlas behind the 6l80 and well at that cost, it need to rethink my crypto strategy:)
Well Jeep peeps have been begging to have a V8 392 powerplant for ages, and they just responded to their calls. I doubt any 25 yr old plus rigs were designed to handle 40" tires back when they were in R & D....lol
i know how what you mean, what was your avg. speed in those elevation and 7% grade?
Since i know the road real well i try to keep up my speed on the down hill portions, that way i can get a running start up the grades. If I'm lucky, and don't get caught up it traffic, or stuck behind a motor home, i can hold around 50 MPH or so.
But if i get stuck in traffic, or it's a real long uphill climb that'll drag my speed down to around 35 MPH with no way to recover until i hit the next downhill stretch. So I'm stuck crawling along in the slow lane watching Yugo"s pass me. Ah, such is the life of a non V8 equipped Land Cruiser owner living in the rocky mountains.
**update**
FF rear axle sourced. Time to clean it up, paint, and install. Wish it was a locked rear but hey it’s better than the drum rear I have now.
I dunno, unless full float is stronger, i have yet to break a semi float axle in 5 yrs, so what exactly is better?
As for braking, i can lock up all 4 wheels if i needed to, with 37s and beadlock, the drum brakes are more than capable, what more do you need?
Pretty much what bhsdriller mentioned and rear discs much easier to work on. I’d rather deal with them than drum brakes. The opportunity presented itself to go this route as well.
Much like I needed a LS vs 3fe.. I can keep up with traffic and merge.
Disc brakes are pretty nice if you drive in the rain a lot or go through deep water. It takes a while for drum brakes to shed water. Disc brakes fling water outward and dry quickly. Really nice if you do a water crossing and then climb a hill. If you try to stop on a hill and the rear brakes don't grab because they are wet you get the fun experience of flying down a hill at 20mph with only the fronts willing to lock up. But drum brakes get the job done and are reliable.
Found your built thread! so what did you do on the brake switch wiring? Relay set up for signals? Also, on the trans cable, I noticed you did the mount on the transfer case. I’ve seen it off the shifter plate and like yours better. Is it more inline off the case?
Also, Thank You for all your help so far. Timesaver for sure.
Sorry just saw this... lol.. I think it's more inline off the t-case and I didn't have to cut more out of the trans tunnel to fit the extra mount off the shifter plate..
Hi. Why did you go with this internal Supra pump instead of the exterior mounted walbro? Advantages and disadvantages? Thanks so much.
It's almost a drop in swap. Easier than plumbing in an external fuel pump, more room for the exhaust to route to the rear, and didn't want to worry about any possible fuel pump noises.
You are convincing Keith. Appreciate it. The LC has a gas return line same as the LS I believe. Did you have to run a corvette fuel filter/regulator?
I bought the lokar rod for the shifter but I'm probably going with the trailblazer like yours. Is this the correct one?
lol.. well those are my reasonings for doing it that way... you could do an external fuel pump if you wanted to.. I am running a corvette filter/regulator. I might swap to am adjustable one later in the future. I've read some corvette style ones vary in psi. Right now mine seems to be reading a tad hi. Wouldn't be hard for me to plumb in the manual style.
that is the shifter cable I used. It's a little long so it'll have to be tucked up out of the way.
man you just gave me an idea. Maybe I'll give this a try. the stock corvette ones cost like 50 bucks.
However, I can't take this seriously. Not sure I can trust Chinesium.
Found this here on ih8mud (Tach wires LS Conversion using the stock tach DIAGRAM - https://forum.ih8mud.com/threads/tach-wires-ls-conversion-using-the-stock-tach-diagram.984636/).
Should be very useful. For me at least as I have a 91. Seems like it can do what the Dakota box can fit the tack tach output.
Looks like the SGI-100BT supersedes the SGI-E8 according to Dakota digital, I emailed the company. “Yes the SGI-5, SGI-8 and DSL modules were combined into 1 unit (SGI-100BT)”. You guys probably know about this but maybe would be helpful to others when they try to order the old version. Thanks all
**Update**
I finally got around to fixing my high fuel pressure. I chalk it up to the Denso pump over powering the corvette pressure/regulator. It’s been around 69 psi since I completed my swap. Swapped it for an adjustable fpr and it sits at 58psi now.
Catch can installed but I hardly get anything. Runs pretty clean.
Alternator and serpentine belt has been swapped out for a higher output one.
Made a lot of progress on my bumper that I’m building. I’ll get started on the driver side swing out. Plan is to make it Like a flat platform to where I can bolt on fuel can holder, jack, or whatever i decide to fabricate.
