My sliders are looking pretty poorly these days. I have had them about 10 years and rocks will do a number on them. How much did you use and how did you apply it, from an Aerosol Can or from a spray gun?
Where did you get your attic storage rack from? Just a random department store?just did my simple ceiling storage shelving 4'x22" just took screwdriver and made hole so bolt can go thru and bolted it in holes where handle goes
i did 3 coats off 3M 08864 and used almost whole 30 oz. bottle i do not know if this stuff comes in aerosol can i have special spray gun for applying this product same gun can be used for something like FLUID FILM coating ...My sliders are looking pretty poorly these days. I have had them about 10 years and rocks will do a number on them. How much did you use and how did you apply it, from an Aerosol Can or from a spray gun?
it is just bottom off shelving i had laying around you can find similar stuff in menardsWhere did you get your attic storage rack from? Just a random department store?
i did finis my swap 100 % and took the car two times to baja california , first time wisconsin to cabo san lucas baja california and second time half the way off the baja and whole west coast off USA so far only one hose camp come loss on fuel line no other problems at allDid you finish your v8 swap?
don't know on which part you need guidance , stock t case 2007 5.3 truck engine with OEM ECU deleted DOD system ,rear o2 sensors VATS also deleted and bunch other stuffAwesome build man. Keep it coming. Anything that you ran into while doing your swap that you could give some guidance on? Did you keep your stock tcase? What trans did you end up using? Stand alone ecu?
just google Southco 62-43-151-2 or you can look on Cam / Compression Latches - Southco for diferent styleAs said by others great build and road tested !
Any chance you have info on the compression latches you used on the tail gate lid ?
They appear to be pretty compact
TIA
Thanks !just google Southco 62-43-151-2 or you can look on Cam / Compression Latches - Southco for diferent style
this heater is not made by webasto it is made by ESPAR and preferable angle off the pump installation is angle 15-35 degreeIIRC that fuel pump for the Webasto heater likes to be level to work best.
thanksJust found your thread. Awesome work! I like that you build what you need instead of buying it. I look forward to seeing whats next.
That’s funny, looks identical. Probably is the same part, just different policy depending on company.this heater is not made by webasto it is made by ESPAR and preferable angle off the pump installation is angle 15-35 degree
i also have webasto heater and it is bit different on outside but internal parts and fuel pump r totally differentThat’s funny, looks identical. Probably is the same part, just different policy depending on company.
I’m way too OCD most of the time.
Nice, like that, unusual to see it on a "tilt" ; any issues there?homemade roof rack ladder
it is removable , works perfectly
