I've run that same HM M1 for the last 130k (of 375k) in my 99 and have seen no issues. There is some dispute here on MUD about HM oil, but as far as I am concerned any fresh, high quality, oil will keep the 4.7 happy.
There has got to be a quality wholesome joke in here somewhere. Dry lube? Come ON man... hahaLubed up all the window channels with this dry lube. No more lethargic windows in sub-freezing weather:
No residue. Works great in sub-freezing temps and the windows don't freeze up!Does the WD dry lube leave any white residue? I need to lube my tracks as well and have some PB dry lube for wood tool surfaces but it’s got Teflon and definitely leaves residue. Been trying to find a different option, seems like a lot of YouTubers use a silicone based but for whatever reason I don’t like that idea.
My belt looked brand new but at 200k my idlers were pretty worn out!Mileage: 186,000
Changed heater tees. The old ones turned out to be rock solid but they were of unknown vintage so I decided to replace them.
Also, took the driver side timing belt cover off to look at the TB - it was last replaced at 110k miles, abt 10 years ago. Looked brand new!!
Thanks Brett!Based on your description, I bet your fuel pump is fine. It sounds like something is preventing the ECU from telling the Fuel Pump Control 'thingamajig' to power up the fuel pump. Did you verify that the security light goes out when you insert the key?
You could check for voltage at the fuel pump harness plug. It's to the left of the fuel tank, between the body and frame. I can't tell you which pins to check for voltage across without checking the EWD.
FWIW - I am in disbelief at how DUST FREE the body is behind the rear trim and jack compartment on BlueEverything back there is always covered in dust on mine. (I may have a few rusty holes in the body behind the tupperware bumper)
FWIW: This might be off-topic here, but I ran into a similar issue with key recognition. I ended up exchanging the security module under dash from salvage yard (behind and to right of radio in between airbag and radio and over vent) vehicle would not unlock with keyless or only driver door and cease responding. Then start but never run despite security light operating as designed (per tech stream and dealer). After having ECU revirginized, new keys, actuators, fuel pump, EFI relay, broken lock cylinder this box seemed to resolve the inconsistent starting issue with key recognition. After the swap, all the keys worked keyless entry and started rather than some working and some not even being recognized. Probably not relevant here but maybe worth a look to at least clean and dielectric grease to avoid other issues. I hope you get this resolved without too much further nonsense. Keep us posted broski.
Dang it!Given that this is an OEM pump, only 24 months old and with merely 20k miles, what are my warranty options?
My Denso direct pump continues to live in the drawer in the back at 215k. My OEM keeps trucking. But it was super cheap so I'd get two and keep one in the truck. They don't take up much room as you know.Looks like the Denso direct replacement (957-003) NLA. Anyone tried other brands like Delphi or TYC?
paging @AlpineAccess , @JunkCrzr89 , @2001LC , @patchagan , @jerryb
I am not averse to splurging on a new OEM unit but 2 years service life is very unsatisfactory![]()
