Yes sir, yes sir.
The passenger is in! And boy oh boy was there A LOT of drama.
Fitting that tall ass strut assembly back in there was an utter nightmare.
So much so that I had to cam out my LCA for the coil seat to clear the bump stop sloped mount in the front to pull the shock mount forward for clearance.
So much so that I had to grind out a sliver of the bucket at each side to slip the top spacer through.
This is with everything but the axle and tie rod already completely loosened.
Including the speed sensors detached, slacked, and UCA zip tied up out of the way (im not dealing with that long bolt again).
Good news is the dual locking jaw style compressors worked a treat.
I had a shock alignment issue at first where the top hat no longer matched up to the bucket.
I had the preload collar exact, and the coil EXACTLY where its indentions were on the top hat.
But that clocked it off by about 45 degrees.
It seems that with the preload, the coil rotates a bit under compression, as i believe is normal for a coil to do.
Since its losing length, the coil twists as it compresses. So if youre anal like me and wanted it perfect, that will not work.
Just mark your shock eyelet and collar and but the top plate out markings exactly lined up to the shock mount eyelets outer rim.
The real fun part was the AHC hose, and as im sure
@Killacaviar knows, you cant really see s***.
I experienced exactly what you mentioned in the other thread (there are so many) but i did not clock the rubber hose standoff.
My ahc hose did not like that sideways movement. If i twisted it into the sideways possition, the hose collapsed in on itself.
Instead i notched both sides and it fell right in.
I even notched the washer to slip into that gap, and stay there.
The pro tip.
When you reassemble the strut, you want to torque your top nut with that hose standoff bushing clocked exactly in line with everything mentioned above.
Trying to safely alter its position is not only pushing the coil against that whole top plate rubber seat, but also torquing your shocks AHC hard line inlet.
I was stupid for trying to align it to the wear marks, when really, lining this up can be done by eye.
This is pretty much how it should look up there.
So with all my love marks, can anyone recomend the best hardening oem like touch up paint for all my maring of the coil, ahc fitting, bucket etc?
