To be honest its great to have that torque when I push my foot but its a bit lazier than I expected (no worse than the CT26) but there are reasons for this that will be rectified soon.
I have discovered that I have an exhaust manifold leak beneath #6 and also out of the section where the two manifold pieces join. I have new gasket, seals, studs and nuts ready to go so I will fix that soon. I'm also convinced that I have a boost leak some where so I will have a go at finding and fixing that also.
Like I mentioned earlier, I had some help fitting the turbo as I wanted some more custom work done to allow the hot side intercooler pipework to fit and allow 4" pipe into the 90 bend onto the turbo. This meant I had to cut the compressor housing discharge pipe off and weld an alloy 90 onto the housing as well as requiring custom, custom hard lines to the turbo as the regular position that the water lines run are in the way. 4" pipe with bends take up a lot of real estate!
So anyway the bloke I had helping me is a bit of a petrol turbo guru and on inspecting the turbo we noticed that the waste gate had zero preload and there was no thread left on the actuator shaft to add some. So we pulled the actuator off to cut some new thread and then Aaron notices a large restriction in the turbine housing right at the wast gate port. We thought that didn't look right, so we ported it out to allow nice flow through the port. BIG MISTAKE! After talking to Luke and mentioning what we did there he basically said that's why its not as responsive as it should be.
Even though this was no fault of his, Luke is going to send me an entire new turbo to bolt on and send the one I have back to him to rebuild and sell again. You don't get better service than that!
For some detail on current performance though, I am only running a rough tune right now and it will achieve 15psi by 1900rpm (same as what the CT26 would do) and will be over 25psi by 2200rpm and at 32psi by 2250rpm.
I'm told that with all my issues resolved and the turbine housing and waste gate the way it was designed I should be seeing 25+psi by 1800rpm. I'm smiling right now but I'm looking forward to that type of response also.
