Taillights (2 Viewers)
Don’t remember what year yours is @xtiaan2000 , but here is the wiring diagram for mine (1977).
Green wire with a yellow stripe going to the right side does brake and turn signal to BOTH bulbs, green wire with black stripe covers both on the left. Sheesh!
Have any of you guys played with flexible resin 3d printing? I've been toying with the idea of getting a printer and as I was doing some background investigating, it seems like products like the prusament flex80 would be soft enough for light gaskets. The main complaint I have read is that its a bit of a slick surface, sometimes has trouble bridging, and can crack under high compression - none of which would be an issue for this kind of gasket... thoughts?
That gasket is shaped like a U, it slips on the front and back of the flat metal light housing . Is that something that could be printed?
Trying to remember how these guys work. I see the four filaments, but don’t remember how each works. Parking, Break, Blinker
Anyone got this on the front of their mind, while I continue to search?
I wasn't able to check brake lights, but when I turn parking lights on, both bulbs light up.
When I turn on hazard lights - same. Both bulbs blink.
Hope that helps!
