Builds SupraCruza (1 Viewer)
“Big boy radiator” Position is finalized
Radiator is mostly plumed waiting on some connectors
Radiator is mounted
will build shroud soon and do ducting
Truck got 1200cc injectors and a new clutch pedal
Just another small update
30 spline t case built to handle 400ft/lbs of torque
Exo roll cage is in progress
Added a oil cooler system
Was able to get her sideways at 2psi of boost
Going to keep the axles so they are the fuse in my driveline and not the tcase or trans
enjoy some pics
this is amazing how am i just now seeing this
I still don't think I know what the end goal for this thing, but I'm enjoying the ride to wherever it is. :cool:
Appreciate it! Just for fun Nothing more
I'd like this post to be considered encouragement for this type of behavior.
Damn that sounds good
And the plan is to run 14” front and rear ori struts
And one of these fancy “sway bars”
Decided Kings were too main stream and these better suit a “rock crawler“ and all I have heard is great great things
Should drastically help the tippy nature of the 80 series
As per usual things change
Got a decent deal on some fox shocks 2.5 3.0 internal bypass raptor shocks and some coilovers for the rear.
wound up not needing the frame in the rear too bad so it’s cut making room for more shock and coilover and ditching a lot of weight.
