I had the good fortune of attending a short course run by Donaldson air filters at work the other day. It open my eyes to a few new facts that I thought I would pass on.
* A clean air filter doesn't catch dirt, it takes time for the holes in the filter media to become blocked by larger pieces of dust. I was aware there was a run in period but didn't realize it was so big, a large machine working under the most extreme conditions in a coal mine will take over 100 Hours before it's filters are blocked enough to become effective.
* A quality paper element filter will hold nearly twice it's weight in dust before it is blocked. Your filter probably isn't anywhere near as dirty as you think it is.
* Stop changing filters, If a piece of equipment working in a coal mine takes 100 hours to prime it's filters so I can only guess how long a car would take. Don't change based on time or distance traveled, install a restriction indicator and change when the indicator show a large enough restriction.
* Power loss due to blocked filters is a little bit of an urban legend. Tests run by Cummins showed that even the most sensitive operator will not be able to notice a loss of power until it exceeds 10-11%, a filter that has just trigged a restriction indicator will account for about 5% max loss of power. So basically any power increase noticed after changing a filter is probably in your head.
* Don't tap filters (even gently) to clean them, this can crack the sealant between the paper element and the filter end caps. Clean only with LOW pressure air, remember you don't want to dislodge the dust that is blocking the large holes. Also remember that the filter isn't as dirty as you think it is.
* Make sure your airbox seals are in good shape. Air will always take the path of least resistance, Your engine will draw massive amounts of air through the tiniest of gaps, size doesn't matter the air speed through the gap will increase resulting in unfiltered air entering your engine.
* A large engine (that being 40 litres capacity and up) will only require to draw half a cup (125 Grams)of dust through it's entire life before it is "dusted" and will require replacement, So I can only guess at how much a car engine could tolerate.
Hope I have helped save people a few bucks, both on air filters and engines.
