Lube your shafts and tighten your nuts!!!
Jeez I HATE seeing this. Someone didn't check torque when it was last rebuilt and worse yet it wasn't checked just out of pure OCDness. So glad no one was injured. Those bolts need to be part of a spares kit. Others will be able to answer your more pertinent questions.
I'll probably use the locktite, too, but I'm curious about those who've said they use locktite then re-tighten on occasion.
I like the safety wire idea.
I'll probably use the locktite, too, but I'm curious about those who've said they use locktite then re-tighten on occasion. I'm assuming they mean to just give a tug to make sure there's no movement of the nut... If the nut moves then that would mean the loctite has either failed or has been broken by the "re-tighten (?)."
I've called my local Toyota dealer with the parts numbers to get the studs, cones, washers and nuts (thank you to those who offered to me from their private stash!). I'll have my parts in a day or so. I want to post here that, as *bloc posted above, "#43211A only indicates the line in the part number index. Front knuckle/steering arm studs: 90126-12005" .... BUT ..... various sites list the part as both 90126-12005 AND -12007. I'd seen one site that said "replaced by" between both part numbers but was presented in such a way that you couldn't tell what replaced what. When I asked the Toyota parts guy about this he said "ummmmmmm.......". I said I'll just bring a nut in (from the driver side) and see if it threads into the -12007.
Also, I have to assume here that the thread pitch is the same on the nut side as it is on the knuckle side.. when I chose the 1.25 mm thread bolts for the temp fix it was based on using a nut from the driver side that fit the Autozone 1.25 template same bolt. It did not fit the 1.5 so I'm definitely perplexed about that. Will post again about this....
So, I've ordered the 90116-12007 stud bolts. Hope that its the same as the -12005 that *bloc says. (!)
Here's an image from one of the confusing sites... note that the #43211A line item applies to 2 different part numbers...
You use a deep wall socket on an extension and just mash it in there. The brake dust shield will flex out of the way a little but will be totally fine.I thought about asking this in the CRITICAL SAFETY ALERT thread, but what's the best way to get a torque wrench on the inner-most of these studs? The angle of them makes it so a typical socket will interfere with the brake shield.
Loc-tite bad.
The steering arm, secured to the knuckle, is a stack of parts which can shear when there is play in the system. Why would you want to use a glue to hold something in place so that you can't tell with a torque wrench if it's loose/developing play?
I figured a little safety wire couldn't hurt
Loc-tite bad.
That "safety" wire is not legit. It doesn't wrap around the nuts; it goes through tiny holes drilled in the nut. Looks purty though.
Definitely bad advice here. Serenity is spot on. Lot's of red loctite and torque.
I use green sleeve retainer for stuff I don't want to take apart ever.
