Who can tell me a part number for this plug thing under the second row seat? One of mine is broken. I'm not smart enough to find it on the parts diagrams.
If one of my rear trailing arms is slightly bent, that a big deal? It seems fine to me.
I wanted an alignment, and dealer said Id need to fix that first, because it would be pointless to align without correcting that. I'm thinking, I just wanted the front done.
Reading online, there is some adjustment for solid axles. Is that why, or is it because the front must be also aligned in relation to the rear, as well?
One of mine is slightly bent after three weeks of wheeling hard a while back and it’s fine. But...I do plan to replace it soon.
A very slight bend isn’t going to shorten it much. But it’s definitrly an indicator that your driving warrants a stronger model.
Most folks never come close to bending them because most don’t wheel is ways that hit those hard and heavy, but apparently you do. Congrats!!![]()
Yes, you'll want to resolve it. The trailing arms dictate the thrust angle of the rear axle. There's no additional adjustments. Bad thrust angle won't necessarily cause more wear, but will cause the vehicle to crab down the road. Even a minor bend will cause a measurable alignment change.
I did that myself....using a floor jack. I'm dumb.![]()
Just tell people you did it on the Rubicon, and unfortunately the batteries in your camera died![]()
Oh dear!
We are all guilty of “dumb” from time to time...
...Some of us more than other.
In your case and your “confession...”
Say 3 hail Land Cruisers and flog your shin with a monkey wrench 7 times, and all is forgiven.![]()
Where's the internal hatch release for the rear upper hatch? I know, it's not there but I miss it. My 60 has it, my 80 had it, and pretty sure the 100 has it. It's rather annoying that the line has had it for so many years and now boom it's gone.
The sensors are tied to the position in the list. If you rotate your tires then they change. You can unmount the tires and move the TPMS around, but as soon as you rotate your tires the positions will move. If you never rotate in your spare then it would stay in the same spot, though you should really do a 5 tire rotation sometimes as if you ever need your spare when your tires get worn down you really don't want one that's half an inch shorter than the other wheels... it's bad for the differentials...Ok really SQOD - I have a 15 LX570. It lists 5 pressures in the TPMS screen, and at present, the spare is in position #2. I'd (obviously) prefer it in spot 5.
Is there an easy way to move them around? In other words, does it list them by lowest ID to highest, and if I put the highest ID in the spare I'm sorted, etc.
I'm happy to unmount tires, move sensors, remount tires, and I think I can manage by setting the tires to different pressures and moving them, but it'd be easier if I knew how the order was determined....
