- Joined
- Apr 14, 2004
- Threads
- 1,472
- Messages
- 36,795
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
Bling.
Thank you, Mark!Bling.
Fair enough but with the hoist doing the lifting it was only a few more pumps to clear the bib. The bib bolts looked kinda rusty and crusty.I always found it easier to do with the front bib off. I also like the extra wiggle room without the battery tray support.
Even the tray was no big obstacle. I could have waited to torque the mount ears back on, though!
Now you tell me!If you take a close look at the bib hinge, the underside has a slot in it so you can slide it out without unbolting it. Mil spec.![]()
Every Land Cruiser needs to be built next to a Mustang convertible. Mine is a '67.The engine rebuild is (mostly) finished and sitting back in the garage. The fun begins!
Ironically, your paint looks like my original color under the black and orange! The PO used the black to cover it in the engine bay.I'm late seeing your progress, it looks great! Might be too late but a suggestion for you- you may regret having a black engine bay. Mine was for years, I finally brightened it up last summer.
Maybe a sliding glass door roller may be adaptableThe hardware on the bifold doors poses a few issues. I need to come up with 3 critical pieces and I could use some ideas to source them.
The pin and socket hinge on one side was missing and one of the rollers is damaged:View attachment 3015836
Any help finding replacements would be much appreciated.
I can probably fabricate new parts if I have to. I'm hoping I can find some used originals before I do.Maybe a sliding glass door roller may be adaptable
Thanks, that's a very good idea. I have some plastic wheels on the way that oughta work but if not I'll go the ball bearing route.Sweet! I used roller bearings from McMaster Carr in place of those plastic rollers. Drilled and tapped holes for small bolts to hold them to the original bracket. McMaster-Carr - https://www.mcmaster.com/#6383K14
