Build Skin Deep: 1963 FJ40 resto
Much progress in the last 2 weeks. I came up with a good replacement door roller from McMaster-Carr:
The OD is on the nose at 28mm as is the 8mm width. only the bore needed enlarging, courtesy of an 11/32" drill bit for a snug fit on the stock bracket.
With the missing parts issues resolved I could refinish the many small hardware bits of the bifold doors, turning this:
into this:
I don't have to tell anyone who has repaired or rebuilt these door latches that they are a fiendishly Byzantine design!
Getting the internal parts and screws yellow zinc plated made them appear brand new and should add durability.
I was lucky that mine were almost completely intact and I only had to fabricate one unique fastener:
OMG! Cruiser Porn!
Reported.
Truly a labor of love. You just made my day seeing that dedication.
Did you plate them yourself?
OMG! Cruiser Porn!
Reported.
Thanks. Mark, you and I are lucky we live so close to Van Nuys Plating in Van Nuys, of all places.
They are one-stop shopping for most plating and polishing jobs one would need. Top quality and friendly!
I hope they never close their doors...
Almost obscene! 👍
This 40 was up at Valley Hybrids in Stockton, CA for the last few months getting some upgrades. Here's the back entrance to Georg's cool shop:
A 4-speed transplant and Terrain Tamer springs with related parts and work were some of the things that got sorted out while it was there.
I should mention that Georg's shop is very competent. I doubt there is anything in a Land Cruiser that they haven't done many times over.
When I got it back I put on the modified spare tire carrier. I wanted the spare to sit lower and right of center so I could see out the rear window.
Success!
It was a straightforward job to cut 2 sections out of the steel tubes and weld them back together. It looks tidier to my eyes now.
I finally got around to registering my YOM 1963 license plates, too.
Georg also sold me some '71-72 factory seat frames that I want to reupholster to replace the not-original seats currently in the 40.
More to come.
The front seating transplant is now done.
Here is the driver's side bottom before:
and the passenger side seat back:
Fortunately the frames were in good shape. I was happy to find a mint driver's side base at Specter who also sold me new foam and covers.
I had the metal parts powder coated silver:
The stock seat height seemed too low and close to the dash for me so I used this 1-1/2" square tube as an adjustable spacer. It works for me.
Here's everything installed:
One benefit of using the perforated tubes is that, with a little bending, the factory adjusters still work with those round holes.
As you can see, the seat sliders are about 2" further back, giving me plenty of leg room now. I may cut off the first 3" of the tubes, though.
These seats were from '71-72 so there should have been a center folding backrest but with the floor shift it would be a lousy place to sit anyway.
I'm thinking of modifying an armrest unless a Mudder has a center backrest they can part with... :cool:
I wanted to re-use my Tuffy armrest/console but it was too tall to ride on top of the bench seat. The best solution was to cut 4" off the bottom:
Next I had a bottom plate cut from 16ga cold rolled steel:
Then I welded it in place:
The seat frames didn't come with the back piece for the center folding seat but I do have the correct foam and vinyl, so I'll get around to that...
For now I attached the Tuffy to a piece of 1-1/8" teak that was gathering dust which I sawed to approx. 12"x19":
Finally, that assembly got bolted to the bench seat brackets.
I positioned the console toward the passenger seat to leave room for the floor shifter. The bracket on the left is to keep it in place on the bumps!
So, what’s the consensus on the hydraulic lifters? False or freakin amazing?… I don’t have the engine experiences in 51 years that some guys have but I have only seen solid lifters and adjustable tappets in any of my FJ40’s that I or anyone else has driven. I like to see that photo also.
It looks like your getting things done…good luck !
Thanks for the question, the answer was in post #11 or so.
My engine builder was also rebuilding a Chevy 6-cylinder and the lifters for that engine were next to mine on his shelf and weren't in mine!
What were the odds? :doh:
This is why I had initially messed up with my IAC Sniper adjustment…. It is right there in front of me yet, I had most likely read that …yet, my brain did not come close to seeing it and comprehending the outcome. Then 2 pages later, I ask you what happened about the lifters.
Interesting thought though on having hydraulic lifters. Thanks for the answer. I thought we may be on the verge of some enlightening tools
