So what did I do to the 4Runner this summer while in the US for 5 weeks? In retrospect, not much. The LC got more attention this summer with new tires and OME shocks and springs.
I did manage to do a few things, some of which are already documented in other threads, but I thought a brief summary here would be good for posterity.
I installed the aluminum plate tailgate cover that I had cut last winter. I also replaced the factory screws and inserts on the cargo trim strip with stainless nutserts and stainless, allen-head cap screws. That stupid piece of trim has never wanted to stay fastened in place but it does now. I also did the same to the factory door threshold trim pieces while I was at it (not that they were ever a problem).
I installed three new grab handles that I had bought over the last few months off ebay: two for the rear passengers and one above the driver's door.
The biggest modification this summer was the upper plenum and throttle body. I replaced mine with a set off a 94 22RE. That wasn't as complicated or as time consuming as I had thought.
Lastly, I installed all new lug nuts and studs. One or two had broken off over the last couple of years so I decided it was time to replace them all.
There were a couple of things that I didn't do that I wanted to get done. I designed an aluminum roofrack but decided not to proceed after getting a price on having it fabricated. I also have some Toyota OEM Land Cruiser 12V outlets that I wanted to install (one in the Cargo area and one in the back of the center console). For some reason I never got around to buying the wire. I have the outlets, the fuses and the empty spaces in my BlueSea fuse block. Maybe next year.
Here's a pic of the tailgate. Not sure I took one of the engine with the new intake. I will have to check the camera.
