I am installing a new American AutoWire (AAW) Hwy 15 harness in my 1970 FJ40. My wiring harness was a mess and consisted of color code red and black, black and black, and an occasional blue wire. I am using AutoMeter gauges and sending units. I built a new rear bumper as my rear frame channel had been butchered and later model turn signals had been installed, poorly, and they were slightly above dangling. The bumper wiring is similar to the gauges in that to remove the bumper requires unplugging forward of the rear channel and disconnecting a bullet for the license plate light.
At this point the starter/ignition bag has been installed, the alternator/charging is installed and I am now routing wires through the firewall to the front. I noted today that the sole power to the headlights is via the yellow wire to the dimmer switch. I will be installing relays for the headlights and there is plenty of wire to route to the left side and use the alternator and to the right side using the battery for power to the relays/headlights.
I popped the $100 for a new turn signal switch. The AAW instructions are based on a person using a GM or similar steering column. Consequently when I get to the loose ends of the wires it is up to me to figure out what to do. The FSM diagram (I bought the laminated, color, version on the net) looks pretty busy. I suspect part of that is the limitation on the size of the fuse panel vs the 15 circuit unit I now have installed. So here goes;
On the FSM diagram, power to the turn signal switch (TSW) is G via the Turn Signal Flasher which is fed from the fuse panel. There is a junction to the VR shown. The power to the Stop Light Switch (SLS) is a junction off the headlight switch to fuse panel. Power to the Hazard Switch is via an inline fuse off a junction to the alternator/ammeter wire.
I can take power to the TSW from the Purple Turn Switch at the Hwy 15 Fuse Panel (#7). I can take power to the SLS from the Orange wire at #9 on the Fuse Panel. It is easy enough to "Y" off of the GO & GY wires to go to the turn signals and stop lights, however, I'm confused regarding the Hazard Switch. The FSM shows a second flasher, my fuse panel defines the flasher as being for turn signal and flasher. Also there is a turn relay on the fuse panel. Operating from the water hose philosophy, if the hazard switch is "Off" there is no water passing through to it. So I should have turn signals and brake lights. But the FSM diagram looks very busy at the Hazard Switch with GY & GO (2 ea) feeding into the switch which shows seven connections. That looks very busy for what should be a DTSP switch. I am thinking that I can combine the GY wires and the GO wires at the hazard and then continue to the front and rear harnesses for turn at the front and turn stop at the back.
Does anyone see an issue with what I am proposing? Do I need to add a flasher for the Hazard Switch? Do I need to find a Hazard Switch with 7 connections? Thanks.
