Replacement for 84222-12010 switch (8 Viewers)
Arlington, Tx
As you know the 84222-12010 fails pretty often on our trucks. Its located on the transfer case, as well as the lockers, and causes the indicator on the dash to blink even when they're working. I recently had the one on the rear locker fail on mine and wanted a cheaper alternative than 60 bucks, so her you go. NAPA Pt# NS6421. Its a neutral safety/reverse light switch found on many toyotas and is exactly the same as the 84222-12010. Retail price is 22.49
Awesome timing! I just called and ordered one to pick up on Monday.
Is this the same switch that is on the top right of the transfer case? Is it plug and play, same quality as Toyota OEM??
Nice find! -- wish I knew this a month back when I had a 3rd member shipped over & back to Carl / justdifferentials -- I had the plastic shroud flattened in transit on my switch & had to buy a new one.
Oh well, I guess I kept Dan in Keystone & the dogs needed food too.
I got one from Rock Auto. Selected a 2000 Tacoma, 2.7L, Under the "Electrical-Switch & Relay" category selected "Back Up Lamp Switch". There are four brands available, I went with the BECK/ARNLEY Part # 2011788, $18.19.
Comes with the washer, bolt on, plug in, fit and works great. Just did 9 days of wheeling in SE Utah, worked every time.
For those of us in the Oceania region the replacement switch is a tridon TRS007.
This is a reverse switch for many models of Toyota.
quick question: how do I check if the rear DL switch is faulty ?
Just bridge the contacts in the plug ? I think I may need this switch,, tks
Exchange it with one from your lockers or transmission, front locker is easiest.
For the pickers out there.
Lots of models to choose from.
Date range Model Frames/Options Found in diagram
08/1987-05/1992 TOYOTA COROLLA AE92,95 84-01: SWITCH & RELAY
09/1990-07/1993 TOYOTA COROLLA AE95 84-01: SWITCH & RELAY
08/1986-07/1988 TOYOTA CAMRY SV2*,VZV21 84-01: SWITCH & RELAY
08/1988-05/1991 TOYOTA CAMRY SV2*,VZV21 84-01: SWITCH & RELAY
11/1995-07/2000 TOYOTA RAV4 SXA1* 84-01: SWITCH & RELAY
01/2006- TOYOTA FJ CRUISER GSJ1* 84-01: SWITCH & RELAY
11/1995-07/2002 TOYOTA 4RUNNER RZN18*,VZN18* 84-01: SWITCH & RELAY
08/2002-07/2009 TOYOTA 4RUNNER GRN21*,UZN21* 84-01: SWITCH & RELAY
08/2009- TOYOTA 4RUNNER GRN28*,TRN28* 84-01: SWITCH & RELAY
08/2004- TOYOTA HILUX GGN15,25,35,KUN1*,2*,3*,LAN15,25,35,TGN1*,26,36 84-01: SWITCH & RELAY
01/1995-08/2004 TOYOTA TACOMA RZN161,171,VZN160,170 84-01: SWITCH & RELAY
09/2004- TOYOTA TACOMA GRN2**,TRN2** 84-01: SWITCH & RELAY
01/1995-08/2004 TOYOTA TACOMA RZN140,150,19*,VZN150,195 84-01: SWITCH & RELAY
01/1990- TOYOTA LAND CRUISER FJ,FZJ,GRJ,HDJ,HJ,HZJ,KZJ,LJ,PZJ,RJ,VDJ7* 84-01: SWITCH & RELAY
01/1990-12/1997 TOYOTA LAND CRUISER FJ80,FZJ80 84-01: SWITCH & RELAY
01/1998-07/2007 TOYOTA LAND CRUISER UZJ100 84-01: SWITCH & RELAY
11/1995-12/1997 LEXUS LX450 FZJ80 84-01: SWITCH & RELAY
01/1998-07/2007 LEXUS LX470 UZJ100 84-01: SWITCH & RELAY
02/1999-09/2006 TOYOTA TUNDRA GSK30,UCK3*,4*,VCK30,40 84-01: SWITCH & RELAY
09/2000-10/2007 TOYOTA SEQUOIA
I got mine at Lordco for $19 I used the napa number to cross and Lordco had the part in the store.
Was looking for one of these myself and found them under:
1998 TOYOTA 4RUNNER 3.4L V6 : Electrical-Switch & Relay : Back Up Lamp Switch
The above Beck Arney lists for $16.04. The same part number as in the pic above. Shipped is $17.11 (1.07 shipping) My order is going in.
