Rebuild 74 FJ40 RHD from Down Under - 2F to 2H to 12HT - 40 series Axles with 80 series Coils (11 Viewers)
Can only do this with the early ff diff that has 8 bolts holding on the backing plate. The 4 bolt ones will require a special bracket - which is whart he seems to have used in this rebuild
Hi Andrew
Mine is a FF with 8 bolt flange - please tell more :bounce:
Hi Rob.
I think you may have covered this Q before but a search didn't help. What tach did you use on the 2H and where is the pickup from ? A buddy has a FJ60 converted to 2H and wants to try to use his tach ?
TIA :)
OK I'm back and back it seems for more punishment. I have decide to do another gal chassis, this time with coilovers and bolt my current tub, wheels, 2h diesel, gearbox, disc brakes etc onto it.
I look like getting a fellow forum member here in Australia to do the pre-fab on the chassis as I need a qualified engineer/welder so it will pass the Motor Transport Authority.
All my other components are already certified so that will make it a little easier, so it will end up a matter of pull it all off and put back on the new chassis - I hope!:p
Well I bought another chassis, this one was already gal'ed. I have asked a fellow forum member "Brooksy" who is also a member of Australian 4x4 forum with me as well to do the mod & welding to the chassis as I don't have the room or equipment to do the this part of the chassis work.
My plan is to use toyota OEM parts, I wanted to keep the fj40 as a whole chassis and use the original front & rear axles, but install 80 series coils around. On top of that I will be still using the 2H diesel but with a 5 speed gearbox this time, also will be fitting rear disc brakes as well, same as last time. \ and 60 series power streering box.
What I hope I will end up with is being able to lift my whole FJ40 (extended to a FJ43) sports fibre glass body and drop it straight onto this new chassis. I can then alternate between chassis over a 5 year period, I can clean & refurb one chassis while using the other.
Once Brooksy has the chassis work done I can then build the knuckles, diffs, disc brakes, motor, gearbox etc etc etc.
The following photo's & explaination have been taken & written by Brooksky.
Basically the customer is currently using his 40 but wants a chassis that is running coils so when the time comes that the current leaf configuration gets a bit much he can then drop his parts onto this chassis.
Now a couple difficulties that are a bit out of the ordinary but it is what the customer would like so I am happy to accomidate
We are sticking with 40 diffs & the wheelbase is being restricted in certain areas so the custom fibreglass body won't need much modifying to make the swap easier. I did have 1 issue & that is the chassis that the customer bought was already galvanised which made for some headaches with cleaning up, bolts being fused in & galvanising being built-up in every nook. It took a lot more time dressing down especially where parts needed to be welded on as you need to make sure you grind down below ALL the galvanising to guarrantee a good quality weld.
So here are a couple pics for you all just to show how things have progressed.
I forgot to get pics of the 80 series chassis that was the donor for a lot of parts to make the job a little less expensive. Also the diffs in there strip down stage & completely cut & ground clean ready for coil brackets & mounts.
Chassis in it's bare state with most old unwanted brackets & mounts cut off.
A lot of tapered cutting was required to get true fitment of coil mounts as some of you will know the 40 chassis tapers out in width basically from the firewall all the way to the very rear crossmember/bumper.
Lower trailing arms chassis mounts. Ignore the writing as normally under an 80 series these mounts are flipped but due to the width of the 40 chassis & still being able to maintain the diff mounts on the 40 diffs without being too wide I mounted the brackets like this to maximise suspension control. The chassis tapering out plus the mounts allowed the trailing arms to have some triangulation, not much but some which certainly isn't a negative.
On to the front & this is where it gets a bit tricky due to the 40 housings. Trying to have enough room on the drivers side for panhard bracket on chassis, idler arm clearance & mounting a steering box (either 75 or 60 series). Also having clearance on hub steering arms & idler shaft from radius arms & on passenger side panhard bracket indiff housing. The other issue is the diffs aren't wide enough to match the coil perches on the chassis so the diff coil hats are 10mm inboard on each side. I am going to have to modify internal bumpstop as I think it will fowl on the coils but I think I have a fix for that. Getting the right caster is also important so I could set-up coil & shock mounts & more importantly radius arms. I solid mount the diff housing into position. I have used some RHS box as my datumn for all measurements on the front of the chassis once I was happy with it being true.
Anyway here are the last couple pics
Got a bit done inbetween other jobs
Made the chassis mounts for the radius arms. Where they mounted the chassis started the taper out so I had to bend the front of the outer plate & the rear of the inner plate.
