Propeller Shaft
That rear driveshaft looks to be much too short. Given in the pics the schakcles are almost inverted, I'd say the first big bump you go over will cause the splines to pop out...
How does it look now you've got the body on?
Propeller Shaft
Can only do this with the early ff diff that has 8 bolts holding on the backing plate. The 4 bolt ones will require a special bracket - which is whart he seems to have used in this rebuild
