Rear lower control arm bracket protection (1 Viewer)
Are these going to require a weld as pictured above? Also, the first bracket looks like it bolts to the old mount and has an indent for the mounting bolt for the control arm/mount. How will yours mount? I would rather that the bolt pass through both the protection bracket and mount. This, with new and longer mounting hardware would ensure simple installation. A weld would up the complexity on these, but make them that much stronger.
Answer:
Supporting Vendor
Mine will use the bolt that holds the control link/arm. Can't use the other hole on the frame mount as it will not allow a bolt that would NOT interfere with the JJ.
Weld the sloped angle steel or drill and add self tapping bolts."
Interested . . .
Answer:
Supporting Vendor
All,
As I told C, I will most likely make these where the frame tab can be welded OR drill and tap the frame. Either with 3/8" self tapping bolts or 3/8" button heads for the guys that decide to tap. When I make up the pieces I will have the laser shop cut 2 holes in the tab for that purpose for those that want it.
I recommend the welded route. After slamming on a bolt a few times it will come loose or shear off.
I'll try and get the rough design finished up tomorrow or Friday.
J
Can I get a consensus if you preffer:
A) weld on version
B) Bolt on version
C) Bolt or Weld on flexibility?
In if still building the list.
C: Bolt or Weld
Just so everyone knows in advance. You will have to drill the frame and then run a pair of thread cutting bolts/screws per skid.
I will supply:
2- skids
2- 14mm grade 10.9 bolts and nylock nuts
4- thread cutting bolts/screws, either Hex or Torx head (checking availability for strongest choice)
J
Maybe I'm not paying attention, but I didn't realize @reevesci was going to be the fabricator. From the looks of his other work, I'm sure these will be nice.
I would think that almost any solution would need to be welded to provide real protection and support for the bracket.
I'm in for whatever is produced.
