I've been working on my cooling system and finding micro leaks. The biggest one was coming from the rear heater. The hose dry rotted to the pipe, which I believe was already cracked and deformed even before I got to wrestling with it. Regardless, this is where I am at. The heater worked and I'd like to get it back in there, but what options do I have for replacing this pipe?
This line goes into the valve, which then has a connector before it goes into the core. Looks like the valve pn is 87240-90A01 and has the pipe, but is discontinued. I'm going to give a Japanese source a chance, unless there is an easier solution.
Also, if I wanted to get things going in the mean time, is there any reason I can't put a bypass hose connected the two lines where the heater is?
