when I replaced the seal on mine since it was leaking from there, the factory replacement one did not seal due to the wear on the shaft, so I had to find a couple of slightly larger seals to find the size that would work.
@SNLC I just got mine rebuilt by them, glad I saw this, now that I think about it I don't recall seeing the seal either, better check when I get home
Hi there, have recently replaced mine, it's the one on the right, My truck is 1991 jdm PZJ70, with a solid flywheel replacement, I,ve had 2 PZJ70s and done them both. Ive a spare in the workshop if you like dimensions. Great refurbishment thread !Unable to find the correct throw out bearing, one was assembled to suit the flywheel swap.
Cheers
Hi there, have recently replaced mine, it's the one on the right, my truck is a 1991 jdm PZJ70, with a solid flywheel replacement, it's the second I've owned and done, great refurb thread, let me know if you would like me to take measurements as I've said spare on hand in the workshop,Unable to find the correct throw out bearing, one was assembled to suit the flywheel swap.
Cheers
Yep mine was missing also, ugh, had my box installed back in the truck with the pitman arm on and torqued, I hope it will come off without too much hassle. What kind of puller works the best on these?
Also I looked up the part # of 9031136005, which is one digit off from the one @SNLC provided, just going to order both to be safe.
ThankView attachment 1943201View attachment 1943220
Hi there, from fork contact surface to the clutch side of the bearing is 46.2mm. P/N on box is 58TKB35003AR ENSS 812 no sure if it's true to label tho, here's some photosView attachment 1943495View attachment 1943498
Yes you are correct, unsure of the measurements as it's installed nowFrom my measurements that is the same length as the stock 1PZ t/o bearing.
Don’t you need to make up the difference in thickness between the single mass and duel mass flywheels?
Cheers
The flywheel I have installed is 51.5mm from back of crank to friction surface - this is info from my clutch guy over the phone,Yes you are correct, unsure of the measurements as it's installed nowbut going as good as new, I'll make some enquiries this end and get back to you, Cheers
he also cautioned against the use of a 1hz flywheel because of the ring gear location and meshing with the SM, apparently its further back on the 1PZ than the 1HZ. Hope this helps![]()
Its locally manufactured specifically for the 1PZ.
The OD ring gear tooth to tooth measurement is 356 mm.
Ring gear axial location starts 9mm from back of crank.
How doe this compare to yours?
Cheers
Just a thought, if you put a 1mm washer under the release fork ball with the increase in moment you may have your 5mm.. no, on second thoughts there will be almost no increase, due to no moment increase, alternatively you could have another machined up providing there is enough clearance in the bell housing.I will let ya know!
As mentioned earlier in the thread, I sourced all my parts from a thread on an Aussie forum where the guy who did it have all the details including the part number for the throw out bearing. I bought that bearing, I believe it is from a Coaster bus. It is the same length as a 1HDT H151 but obviously has a larger ID than a R151. It is also the same as an OEM t/o bearing I have for a 1HDT h151. It is longer than a t/o bearing I have for a 1FZ h151. I also have the old t/o bearing from the 1PZ as well as a new OEM one from a 2007+ HZJ76 with the R151, it is a touch longer than the 1PZ one. I have taken a rough measurement and came up with needing to be 5mm longer than the 1PZ one.
I will do some measuring tomorrow and see what I come up with. Thanks for the numbers and help.
Cheers
The IP look great, looking forward to the results.
