So begins the adventure in amateur mechanics. I did my YouTubing and read through accounts of people like me doing locker installs .I was emboldened.
First step was to make it easier to work on, so I took some measurements and broke out the plasma table at work. This thing is my favorite new toy. I made a quick sketch on the laptop and before I knew it I had a yoke to bolt onto the differential flange. A little scrap pipe and I had a way to mount and swivel it in the vice.
View attachment 3224963Here’s the gear pattern before I tore it down. I think the differential was in good shape. It pains me to replace all the hardware since it was in good shape, but I understand this is the way.
Then I forgot to press the inner(rear?) bearing out and fubar-ed the bearing spacer knocking the race out with a hammer and drift. Luckily the new install kit comes with a set of shims. Time will tell…
View attachment 3224964This mother is kicking my butt. I’ve tried two different pullers, but it keeps deflecting one way or the other. I have it in the freezer currently, hoping the shaft will contract more then the bearing I’m open to suggestions.
On the flip side, the ring gear went on easy as can be with a little from the oven. Bearing will have to be sit til next week.
No pics but I also got the air fitting tapped into the case.
My initial backlash measurement was 14 thousands. In my internet research I found that the backlash should be 5-10 thousands
or returned to the initial backlash. Which is it?
In my mind, this’ll likely honing in three steps, this will be the first. The next is to finish the differential assembly. Hopefully the next week. After that I’ll install it with the chromoly shafts. Hopefully all this happens by mid February, because February 27th I’m headed to Sand Hollow!!! Hopefully, it doesn’t snow!!!
