Builds Project Rosie Ruby the Poverty Princess (7 Viewers)
No, No...
Mushi Night!
She is heading down to @kelly saad next week! Cant wait for the next phase...recall a year ago Kelly said he was a year out, he was right!
@Cruisers and Co crazy how much changes in a year...you have a fully blown shop building awesome rigs, filled the turbo void in the most responsible way possible and have been an amazing partner in all of this...better yet a friend.
@JohnnyUtah2 you now are a member of the Cruiser & Co team! How cool is that? What a crazy journey!
Honestly all of these relationships and helping out the community, the companies and the people are so rewarding to me. Maybe I actually just love you all and not really land cruisers...they were just the vehicle to bring us together...and sushi... @OGBeno
Brett, it's truly been a pleasure working on your truck, thanks for working with us on it! Can't wait to see what @kelly saad does with the paint! Going to be a one of a kind 80 for sure!
This for @OGBeno
Hood
• 53341-60100 Hood insulator
• 90467-09014 Hood insulator clips (x12)
• 53383-60010 Weatherstrip between cowl and hood
• 53381-60010 Weatherstrip between hood and core support
• 53184-60050 Weatherstrip LH headlamp and hood
• 53183-60050 Weatherstrip RH headlamp and hood
• 53450-69015 Hood lift support (Left)
• 53440-69015 Hood lift support (Right)
Front Left Fender
• 53088-60906 Fender flare and hardware kit
• 53852-60030 Fender flare gasket
• 76604-60021 Mud flap
Front Right Fender
• 53087-60906 Fender flare and hardware kit
• 53851-60090 Fender flare gasket
• 76603-60021 Mud flap
Rear Left Fender
• 61062-60903 Fender flare #1
• 61064-60905 Fender flare #2 and hardware kit
• 61783-60071 Flare #1 (door) gasket
• 61784-60090 Flare #2 (fender) gasket
• 61788-60011 Flare #1 (door) small gasket
• 61787-60011 Flare #2 (fender) small gasket
Rear Right Fender
• 61061-60903 Fender flare #1
• 61063-60905 Fender flare #2 and hardware kit
Front Left Door
• 69220-60020-G0 Door handle assembly, factory 6M1 - repaint if needed to match
• 75720-60021 Belt moulding
• 68151-60010 Window glass run
• 87941-60010 Gasket between mirror and door
• 67862-60073 Weatherstrip
• Install new door lock cylinder, retain old cylinder for customer
Front Right Door
• 69210-60020-G0 Door handle assembly, factory 6M1 - repaint if needed to match
• 75710-60021 Belt moulding
• 68141-60010 Window glass run
• 87911-60010 Gasket between mirror and door
• 67861-60073 Weatherstrip
Rear Left Door
• 75740-60020 Belt moulding
• 68152-60011 Window glass run
• 68189-60010 Weatherstrip for small window
• 67872-60043 Weatherstrip
Rear Right Door
• 75730-60020 Belt moulding
• 68142-60011 Window glass run
• 68188-60010 Weatherstrip for small window
• 67871-60043 Weatherstrip
Left Quarter Window
• 62906-60020 Louver LH
• 75670-60020 Belt moulding LH
Right Quarter Window
• 62905-60020 Louver RH
• 75660-60020 Belt moulding RH
Windshield
• 56121-60100 Gasket
Back Window
• 68291-60050 Gasket
Tailgate
• 69090-60100 Liftgate handle assembly
• 69215-60020 Liftgate handle
• 68838-60020 New gaskets for upper hinge to body (x2)
• 75435-60040 Upper tailgate TOYOTA LAND CRUISER badge
• 75441-60020 Upper tailgate sombrero badge
• 75431-60060 Lower tailgate FULL TIME 4WD badge
• 68950-60040 Hatch lift support (Right)
• 68960-60030 Hatch lift support (Left)
• 67881-60060 Weatherstrip back door
• 68281-60010 Weatherstrip liftgate
Rocker Panels
• 61412-60021 LH outer rocker, R&R if needed
• 61411-60021 RH outer rocker, R&R if needed
That comprehensive parts list is courtesy of @truthdetector THANK YOU!!
That's my favorite cruiser interior. My first 80 had the same interior before I sold it.
Wow, never knew about the dash pad! How much for that beast? I woulda bought one years ago.
What're you using to remove old paint? Seems to work great!
Several different tools but for the majority, I use a polisher with a 5" hook and loop pad. Starting with 40 grit on this one because the paint is so thick, then switching to 80 after I get close to metal. Conditioning discs on my Aircat 1 HP die grinder in the body line areas, but you have to use sandpaper behind those places because the conditioning discs don't leave good scratches. Makes a huge mess everywhere in the shop. We try to do it outside when possible. Before primer, I sand everything with a DA and 100 grit also.
If you know, you know. @kelly saad the artist and magician!
