Build Project Lockjaw-1973 Fj40 on Tons
When I go to their website, it says opening soon and there’s nothing there to look at
I see that. They closed for a bit to restructure but they reopened. I purchased some cowl parts from them after they reopened but I ended up returning them. Perhaps they closed again?
Why don’t you want the CCOT or SOR parts?
Well funds are getting tight. Can’t see myself spending $400 on patch panels. Heck, I may just make my own.
Started patch work on the passenger door
Thinking of installing a hydraulic hand brake so that I can lock up the rear and do front digs. Anyone done this? Any suggestions for brands?
A common manufacturer of these components closed shop during Covid, CNC Brakes. There may be parts available here ant there, but I would personally go with someone like Wilwood, EMPI, or Jamar.
If you're going through the work to install, and you have a selectable rear locker, I would do a brake cylinder for each rear wheel. If you do not have a selectable rear locker, then you will only be able to lock both calipers, as locking 1 gives you no advantage to just locking both. I have turning brakes in both my sand buggy and rock buggy, and they do work. 99.9% of the time, its just a novelty and not being in a competition setting I only use them because they are there. I have found they are a bit finicky and if you push the brake pedal before releasing the hand turning brake, it hydraulically locks the caliper that you were actuating with the hand brake. I've ruined 2 sets of pads/rotors on my sand car now due to this.
The buggy I just sold had them and they work really well.
Like @EWheeler said you really need cutting brakes, the ability to lock each rear wheel independently.
Nearly all high end & competition rock buggy have this.
IMO it’s a must have 😎
Anyone ever use JT Outfitters wiring harness!
JTO 👎 IMO.
Check out the Kwik Wire products, just as nice or better than Painless at probably 1/2 the price. And 14 circuits frankly isn’t near enough when you’ve got additional electronics, fuel injection, lights, ARB compressors, etc that all need power. Think I got a 22 circuit for the 715
Thinking that I’ll just freshen up the under dash harness.
I did this recently on one of my 40's. It was an impressive pile of wire and plugs that was removed and quite satisfying to get rid of all the unnecessary plugs, wires, and controllers. I went slow, thinking I wouldn't have to strip the entire harness of the factory sheathing, and it was a total waste of time as I ended up removing the entire length of the harness wrap. Just start removing the sheathing from one end and zip tie the branches as you get to them so you don't lose the "shape" of the harness and it will make much quicker work of it.
So I'm toying with the idea of putting my rear coil overs on the inside of the frame. A piece of c-channel that ties the two towers together and mounting the coil overs to the c-channel. Kind of like Toyota trucks have them mounted. Maybe this would give me more flexibility?
I've never "built" a coilovered truck, but you are going to have better stability and control with them outside of the frame. Dynamic forces act on the vehicle at the center of gravity, and the further away from that point you control those reaction to those forces, the smaller the force has to be to resist/control for stability. I think it is worth figuring out how to package them outside of the frame, even if you need to make frame modifications to do so.
Well with all of the panel replacement, my rear hatch had a 9/16” gap on the drivers side and about a 3/16” gap on the passenger side. Decided to cut the rear corners that wrap around the back out and flex the corners to fix the problem.
Found some braces that go under the rear wheel wells that I ordered a long time ago. Got both sides welded in
Made some new corners. No pictures of those but will post in a few days once they are welded in
