Did you paint these yourself? I have got some things that I need to sand and paint.the previous owner did a sweet time-lapse video when he did the main build. mine will be pretty mild from here out, just cleaning up age-related issues.
/2 job in my opinion. we will see what the transfer case yields when I get to that next month...Which size and part number did you go with for the red and yellow tops?Enter the Slee dual battery bracket (Slee Part# SOF1251), its 100% ready to bolt in and accept a standard full-size battery of your liking. Now to the batteries themselves, opinions here vary about as widely as tire selection. I've been running Optima's in my FJ40 for nearly 12 years, Odysseys in my Tacoma for over 5 years and a smattering of others in other rigs I've had. Given my ability to run a full size battery and my need for one standard and one reverse battery, I opted for the Optima Yellow Top in the auxiliary position and the Optima Red Top in the starter position.
I have them in the service log, I will give it a look when I get home, I think the yellow may be due to for replacement, it is not holding a charge anymore.It’s been seven years, I’ll have to see if I can dig up the specs on the batteries![]()
so better late than never I guess, the red top that is in the truck is a 34R the Yellow top say D34/78 for the model number.Which size and part number did you go with for the red and yellow tops?
the ARB rails and steps are not sliders, these ones have been bent and straightened out more than once. that being said the is no damage to the rockers...Hey! Love your build. I'm modeling mine after it... albeit with a few deductions due to the kind of use it'll see and my slightly tight budget. What did you think of the ARB rails and side steps? Are the steps robust enough to take the weight of the car should they need to be used as true sliders? Have you had them in those circumstances? I saw a few photos from the rubicon where they were on a 80 series and just completely bent while sliding a high drivers side rock. I don't know that I'll be doing a ton of that kind of driving but I would like them to be able to act as sliders should I need. The side rails are a huge advantage in my opinion but only really able to work with the arb steps/bumper. I have the front bumper on already. Any sage advice would be much appreciated.
well, I have put about 10k on the truck with just the hubs and I like the 2WD, it has taken a minute to remember that I need to get out and turn in the hubs like on my 40, but that doesn't bother me unless it is muddy, rainy or snowy, but that is the nature of the beast and I am ok with it.I am so tempted to do the part time conversion, let us know what your impressions are after some miles.
it is pretty awesome, I took a longer lunch and headed up to the "B" and it pulled awesome up 4th north, didn't kick down to a lower gear. once I was up in the dirt I was able to mess around in 2WD, 2WD-low, 4WD-high and 4WD-low. pretty sweet! it acts just like having a twin stick setup. the 3.1:1 is awesome, I actually had to give it some gas on the downhill.Right on, I’m excited to drive it!
