Wish I could have found this color vs the Champagne I have. Love the green mica.
the battery is new. I replaced it last week and everything is running well but the light is staying on.How old is that battery?
They do not like to go dead...
I don't know if the brushes have ever been replaced... but since i am getting a consistent high reading on the gauge it seems like the Alt should be fine?When was the last time that you replaced the brushes in the alternator?
Also, if you have mil spec terminals, did you also tighten the cables to the terminals. I had an electrical issue with sporadic charging problems recently where that was the issue. I had tightened the posts, but not the cables... Whoops. It was nice that the fix was so easy.
My thoughts exactly and I said as much in the other post.I'm confused. In this post you say you are getting high readings, but in your previous post you used words like "minor charging" and "sporadic at best". If you battery light is on and you are not getting about 14 volts + or - from your alternator after starting, then your symptoms are like mine were. Your alternator needs rebuilt or replaced. Mine put out about 12.8v for week or more before it fell to 11.7 and the dual batteries and solar here and there couldn't keep up.
forum.ih8mud.com
How did the MC rebuild go?A couple of weeks ago i noticed a brake fluid leak... i have pulled the brake master and have commenced the rebuild. As i got into it i found that there was fluid in what i think is a vacuum line, I am hoping that rebuilding the master cylinder solves the leak. any input from you guys would be helpful.
i am slowly getting it done, after starting to rebuild mine and seeing how crusty it was inside i opted to try a rebuilt unit from Andy Lee in California everything is hooked up and waiting for me to finish the bleed. i think all i need to do now is reset the ABS since it keeps beeping at me.How did the MC rebuild go?
What is your latest opinion on the front drive conversion? And is the only parts needed the hubs? So you don’t have to tear into the axles?
I am really liking it. up front all that is needed is the hubs, but to make it true part time you will need to install a spool in place of the center differential. I think it is way easier than working on my LV....What is your latest opinion on the front drive conversion? And is the only parts needed the hubs? So you don’t have to tear into the axles?
Cruiser Outfitters also offers a fully rebuilt t-case to drop in so you don't have to mess with the gears and everything. I am super glad that i did that along with the under drive and low range gears. you know "because I was in there"...
Did you have the dreaded clunking of the drive train that is so common on our 100's? I was told this conversion eliminates that issue bc the front is no longer under full time power while on the street and disengaged. Is that correct? What do you mean about the "spool" in the front dif?
