those are just rubber hoses. You can source them from any auto parts store. They do not have to be specific from Toyota. Just make sure they are rated for ATF fluid.
You need to also remove the skid plate to get to the bracket holding the high pressure hose. Careful, if the hose has been leaking there will be oil collected on the skid plate
Is there any reason not to go with a rebuilt pump in this case?
Because you don't know who rebuilt it, how good of a job they did, or how worn all the internals are. I'm assuming they just put in a new bearing and seals and don't get into things like examining the vanes for wear. By all means put in a rebuilt, but I'd keep the original and rebuild it as a spare. The Gates kit is something like $20, plus the bearing.
Once you experience the joy of replacing that pump you may find that you have no desire whatsoever to do that job again any time soon. Therefore a new OEM pump is preferable.![]()
X eleventy billion. My 80 is 21 years old and has 250k miles on it. The starter and AC compressor went out very close to one another. I decided against rebuilding either. My alternator, fuel filter and PS pump were all original. I decided to order new Denso starter, alternator, AC compressor and AC dryer. I also ordered the PS pump rebuild kit. I already had an OEM fuel filter on the shelf. Lastly, I ordered the bearing, PS low pressure hoses and the charcoal canister hoses that the phhkit guy sells.Speaking of that, I happened to have my alternator out already when I tackled the PS pump and I was confused about all the comments about how hard it is to pull. If you need to do the PS pump, I highly recommend pulling the alternator. Replace the brushes while you have it out.![]()
Anyone know where I can get the best parts for the best price? There seem to be lots of offerings on ebay, but I'd rather spend a little more on a quality pump to avoid having to do this ever again.
Thanks and wish me luck!
So I recently replaced my pump for the third time this year:
Was CDan ever so prophetic when he said:
- The first time was replacing the (probably) original pump. I replaced it with an A1CarDone rebuilt pump.
- That pump failed on the highway and lost all the fluid 2k miles later. I patched it up and got home, and replaced it with a free warranty pump, another rebuilt one.
- That pump leaked from the rear basically immediately, 5 days and 30 miles later all the fluid was gone. I replaced it with a new Toyota pump. My two previous pumps were both refunded, so no loss there.
So the third time I made a video:
I hope people find it useful. It goes along in tandem with this thread.
Sorry asked via my phone and without my spectacles only got the gist, real small gist it was.His post states that the first one went 2,000 miles and the second one took 30 miles to barf all the fluid out of the system.
Sometimes I know more than I know![]()
