Thanks 86...I thought about that but didny know if that could caise the bubbling. I guess if it allowed enough air into the system though it could. Easy enough to test
Yes... its not the original cap. I broke mine some time back. Nobody had them in stock so I went to the salvage yard and got one. I think it was off a lx. the dipstick was too long. I cut it of and the cap went on. I know I need a new one but I didn't think air would be able to get into the system thru the reservoir. There is the 15" section of 5/8 tubing full of fluid that it would have to get past.
I'm going to get a cap anyway... I can't tell exactly what is full, over or under filled.
So here we are again... I tightened the high pressure line going into the gear box just a hair, double checked the torque on the banjo bolt, replaced the low pressure clamps on the hose to the reservoir and made sure they were tight, checked the lines and cooler for holes but I couldn't see anything obvious, bled it until I didn't see any bubbles for a long time.
I didn't pry the top off the reservoir because they didn't come off easy and I didn't want to take the reservoir off. Easy but I don't have any more power steering fluid at the house.
Started it and turned the wheels back and forth. No whine. Shut the engine off. No spray. No froth.
Drive it down the road and parked it. Feels and sounds great. Popped the hood...No puddle on the reservoir. No froth in the fluid.
I'll take it for a longer drive tonight.
I really appreciate everyone's help. Hands down the best forum/interest group I've found for anything
Eventually I'll get it... I'll probably find it's already been dealt with somewhere here.
What do you mean "pry the top off the reservoir"? Is it removable? Mine weeps a bit and it would be cool if I could just change a gasket.
could be a loose cap or the seal on the bottom of the cap isn't holding. This is a pressurized system and the cap should not allow an over flow.
Once upon a time on a mk3 supra my friend changed the ps pump but the whine was still there. Turned out to be a blocked suction screen causing cavitation and noise. Replaced the reservoir and all was well after.
Yes, the system is pressurized, but not the reservoir. The cap is vented, if you beat it in the rocks on a hot day, boil the fluid, there will be a little fountain from the little vent hole in the center of the cap. One of the reasons that some of us have switched away from ATF, fountain entertainment is far less often.![]()
