Inside front bumper.Much better to have you compressor in a cool spot. There much more efficient pumping cool air.
Interesting ideaInside front bumper.
Wish I could take credit for it, but that was Joey’s idea. I believe he has or had a tank mounted under the bumper. Not sure if the compressor is there as well, but it may be. This is a few years back, before the cartwheel.Interesting idea
Sorted my compressor - when I re-fitted it I'd mis-wired the + feed of the solenoid to the very close by earth bolt instead of to the main + stud of the solenoid.
One issue with mine that I'm still to sort besides the idea of a moisture trap on the output is arranging the air connector so it's easier to join up to. My shelf that the compressor is bolted to gives an easy way to secure a bracket that a single (or more) nitto's can fixed to and then a different tap and some kind of hose between the compressor and the relocated nitto fitting.
You don't have to worry about the compressor hitting you in the head on a role over. simple, plug the hose in and start filling up tiresOut of curiosity, what do you guys see as the main advantages of permanent onboard air? I've always just relied on my air up/down "go-bag":
Simple and compact. Connects via an Anderson connector I have in the rear left quarter panel. I can see the need for onboard air with air lockers, but without that, I've never found myself wanting something permanently installed. Where has it helped you guys out?
Personal taste has a lot to do with it and if you run off road much, airing down and back up, unpacking a bag and packing it back up each time, not to mention connecting and disconnecting the power. Time, energy and wear and tear on things - with the compressor mounted and a hose handy - it just makes sense.Out of curiosity, what do you guys see as the main advantages of permanent onboard air? I've always just relied on my air up/down "go-bag":
Probably SleeWhere did you get the bracket for the windshield washer . Installing dual battery setup and need to find a home for it. 97 Lexus
This Kit works like a charm. Did for me, anyway.Where did you get the bracket for the windshield washer . Installing dual battery setup and need to find a home for it. 97 Lexus
The one in the picture is a Slee, about half the price of the DeltaWhere did you get the bracket for the windshield washer . Installing dual battery setup and need to find a home for it. 97 Lexus
I have what looks to be the same but in red. Bought the battery tray but haven't installed it yet . 35" tire at 16psi to 32psi was quite fast and it wasn't that loud.Morrflate 10.6cfm compressor shoved into the battery tray. air line runs down the frame rail. View attachment 3215374View attachment 3215375
There are some upgrades to the morrflate in quality and parts like hose ends and additions to help with rattling handles. Main build is the same.I have what looks to be the same but in red. Bought the battery tray but haven't installed it yet . 35" tire at 16psi to 32psi was quite fast and it wasn't that loud.
Most rated CFM is at 0 psi unless other wise stated.
