Builds Patch's Build Thread (3 Viewers)
C-Clips (c-washers really) in the rear diff on semi-float? I don't see a true BFH on the ground either.
No c-clips in semi-floats. Just unbolt the hub/shaft assy and it should pull out (done it before).
Not sure how anyone expects me to add heat to the internals of the axle housing. I guess i could light a fire inside it 😂
I actually don’t own a BFH any bigger than the one pictured. Never needed it until now i suppose
Got it. Now the issue is that I can't get it back in...the bearing is slightly dislodged. I'll try to press the bearing on and see if that gets the shaft in further
Might be time to throw in the towel and buy another shaft altogether...
Semi-float is some bullish*t. So are OEM rear lockers when you're really using them
The shaft I broke back in November broke at the same place. Seems to be the weak spot on the 100 semi floaters (at least the locked versions)
What finally got the shaft to dislodge at the hub?
Yesterday I was attempting to pull the shaft out of the hub assembly. Today I pulled the entire assembly with relative ease
Now I can’t get it all back in because I managed to pull the shaft off the hub slightly yesterday…gotta press it back on then i can re-assemble
Here's the old 80 thread on the subject of OE rear lockers being less than ideal- Twisted rear axle shaft - https://forum.ih8mud.com/threads/twisted-rear-axle-shaft.239583/post-4572152
Here are some relevant threads I've stumbled across in regards to this.
I'll be attempting to "machine down" my splines on this shaft with a grinder/flap disk next week. I plan to replace the shaft eventually and will have that one milled on a lathe.
Apparently the drawing in this post from @landtank is inaccurate. I can't assume that the 100 shaft is identical to the 80 since they are 32 spline vs 30 spline.
I doubt many 100 owners have had this issue yet and if they have I need to meet them.
Is it possible to run standard LX shafts without the longer splines with something like an airlocker?
Yes lots of 80 guys have had this discussion. Christo chimed in a fair amount back in the 2010s recommending something like an ARB to prevent this issue
42301-60902
I’ll be buying a spare shaft soon. Not sure what I’ll do long-term. It will honestly depend on future problems which will hopefully be minimal now that I’m more cognizant of this “feature”
“Welcome to 37s” - Jason Bush
Just found this super helpful chart for Dyna Bead calculations/recommendations based on tire size/ratio etc:
I've got some wobbles on the highway above 55mph- time to get them sorted
37x12.50r17 requires 10 ounce beads
Stupid vandal- I would call him a thief but he didn’t take anything 😂
Just left me with a mess to clean up and another reason to move back in with my parents (sorry Jimmy and Tricia- you thought you had gotten rid of me)
“And my undies- good thing I brought extra!” - (name who said that and I’ll send you a sticker or something)
Atlanta smh
Same happened to me in Memphis a couple years ago. They didn't know my German Shep was sleeping in the back...
So frustrating when that happens…
To answer your quote, “how to train your dragon”
