over heating fj-40
dgangle what are the dimensions of your radiator? and how much did you have to move around to get it to fit?
did you cut out much or did it drop right in, how has it worked so far?
It's a real close fit, but it fits without any clearance problems..
I bolted up the fenders and bib and measured to see how it would clear the hood and everything checked out good, except it's real close on the hood..
It works great, I got the chassis parked in a 100 degree shop and it keep my 406 at 190 degrees with no shroud and a 16 flex fan, but a shroud it soon to come and that should bring it down more and wind from the vehicle actually moving ofcourse..
Here's a pic, it's the Griffin brand radiator
There's more pics in the link in my sig it you want to see them and my ingenius mounting system..
dgangle said:
Cooling any water-cooled vehicle is a combination of four things: airflow (fan/shroud), water flow (waterpump/thermostat) and fluid at pressure to raise the boiling point. Proper cooling of a Chevota has been debated before and surely will be again. I cannot understand how anyone living where the ambient temperature is over 70-75F can cool a SBC in a 40 with the stock radiator, whether it's 3, 4 or 50 cores deep. I guess it's how one defines "cool". Some go by the needle position on the stock gauge, others with a high-quality aftermarket gauge. To some, anything over 180 is too hot, others may define hot at 230F.
Up to a few weeks ago I tried everything short of a larger, non OE-type radiator: 4-core HD radiator, high flow WP/TS, water wetter, solid fans, flex fans, elctric fans, shrouds, diffferent bumpers, no bumper, remove the winch, snake oil and prayer. Somethings made no difference, while others helped some. The final solution for me was to go larger, aluminum radiator. I do not know why I waited so long. See
https://forum.ih8mud.com/showthread.php?t=92199
It really wasn't that hard. Just more $$.
I am pretty much where you are...if it is above 80 degrees it will run upwards of 220 degrees.and summer areound here is 100+ everyday.I have a 351 W though.but am already running a 2 core with 1in cores alum radiator and a perma cool elec fan.have tried the hi flo water pump an T stat with out much change.not sure what to try next
Regarding the fit.....nothing on an obsolete 35 year old vehicle with a bastard engine bolts right in. I have a bud that has a 350 SBC in a 84 CJ7. I liked how his radiator mounted so I took some measurements, pulled it out and made a cardboard template. I put his radiator back in and used the mock-up when I could get around to playing with mine. It fit really well but I ended up having it made 24" wide so I could fab vertical angle iron mounts directly up from the FJ frame rails. The core is something like 22" wide X 20" tall. The CJ-style mounting system made it easy to mount. I have approx 1/2" clearance on the Saginaw spud shaft and 1" from the radiator cap to the inside of the hood. It fit well but I had to move my custom galvanized battery box back to allow room for the extra width of the radiator. Like I said, nothing bolts right in and previous mods had to be redone to allow extra room not even considered necessary before. My other option was a direct-fit OE-style aluminum radiator like a BeCool but the $400 I saved bought allot of creativity and most said they were inadequate anyway. Regarding the shroud, I was thinking aluminum to match the cool-factor of the new radiator.
It has worked awesome....lowering my operating temps by 25-30F. It now runs 180-195F in 100F ambient temps at any speed/load...and that's with a new clutch fan and no shroud (yet).
dgangle said:
Let me start by saying that I have no reason to doubt what you are saying is true. I tried the same arrangement and my recently rebuilt, stock carb'd mid 80's 350 ran +230F consistently at sustained high speeds or when pulling any type of small load anytime the outside temp was over 75F.
I'm glad it worked for you and everyone's experiences can be different but I think the general consensus of successfully cooled Chevotas involve a bigger radiator of whatever material. I found the stock radiator no matter how many cores it had to be grossly inadequate at the task.
I hear ya, different strokes for different folks. Did you use a taurus fan with your setup? From my experience from the Taurus fan is that they pull an AMAZING amount of air and are cheap. I have heard good things about the aluminum radiators as well. Maybe go with an aluminum and a taurus fan? Not sure if the vortecs cool differently than the older V8's? I am sure there are differences though in the engines and how they cool.
best of luck.
noah
Fellow "pig-daddies"
original poster wanted to give my solution. First let me start by saying "Cool Set Up" dgangle and fman! For anybody interested ("water cooled vehicle is a combination of 4 things" from post #8). For me this was the answer. I bought an aluminum rad 22"x20"x3" $199 and a 18" electric fan $79.95 from summit. A v-8 conversion fan shroud from SOR. FYI - I asked the summit tech staff about a larger rad. they informed me that the inners vary on each rad., so even though this rad is not a monster the inners are designed for a v-8 (I hope their right). Installation will begin tomorrow and hopefully driving by saturday.
Also, "dgangle and fman" why are your engines so clean?????
Kerry "Pig-daddy"
I have a rather hot SBC with a 4 core stock size radiator and a ford taurus 2 speed electric fan. I started with a 160 degree thermostat and had to change it to a 180 degree because it was running too cool (150 degrees). Now it stays around 175 on the road and 190 off road.
dgangle said:
...and my planned shroud. Can anyone recommend someone that could make this from say 0.060" aluminum for less than my first born?
could this work?
http://store.btbprod.com/detail.aspx?ID=44
another post bought up BTB products so I got to looking around their site and saw this and thought of your post...
yeah.... but versus a custom built 1 off aluminum one he was thinking of? think of it relative to what he wanted... betcha it would be cheaper.
(but as others said elsewhere... BTB products ain't cheap)
