Official Classifieds Thread (2 Viewers)
1989 A440 auto tranny. Roached. Free for scrap or parts. Located in Ketchum:
Also posted on C-List, here.
On the hunt for an FJ60 transmission cross member. Needs to be later model, so 1985-1987. Fits "flat" vibration isolators on the manual tranny. Looks like this:
... blingy chrome finish not necessary (stole that image from my related thread, here).
Thanks!
Anyone need an LED Light Bar Switch? Bought it and ended up not using it. It's the white light version. $5.
I got a lot of parts I wouldn't mind getting rid of;
80-series steering box freshly rebuilt by RedHead Steering
Full set of non-fender flare 70-series mud flaps, NEW
HPD of Australia top mount intercooler kit, NEW
40-series speedo cable, NEW
80-series power steering pumps, used and got 2
80/81-series steering wheel, in good condition but used
40-series MAF shackle reversal kit, new
80/81-series 1HDT/FT turbo, one complete and used and the other is just parts
80-series brake booster, used and I have 2
Lot's of little 70-series parts, most are new.
Some 80-series new parts like a few sensors.
1PZ duel mass flywheel and clutch, used but good.
And more....
Cheers
Interested in the 80 series steering wheel, will stop by tomorrow to have a look if you still have it.
Cheers
Do you know if the steering box is the same across all 80’s (3FE as well)? If so, let me know and I’ll stop by to chat.
edit: looks like they are 👍
Ok it is yours if you want it.
$450.
Let me know.
Cheers
Hey Bryan. You should double check the bolt pattern. I know that my 1989 FJ62 uses the same bolt pattern (and thus can use the same steering box) as early FJ80's, though I don't know when that changed. To your point it may have been when Toyota left the 3FE behind. When my FJ62 box wet the bed I found a 1991 FJ80 box replacement. Hope that helps.
$450.
Let me know.
Cheers
Great, I’ll send you a message
Thanks for the suggestion. Based on a couple threads I’m pretty confident, but I’ll check the bolts to confirm like you mentioned.
Making space in the garage.
Fine spline 4.11 ring and pinion 2 sets. Bought these used. Went to have them installed at Jim's driveline and they said they would be noisy if I ran them after they started to set up one set. Not sure if they made sure they had the right pinion with the right word gear or not. SCRAPPED
Also have a diff minus spider and side gears and shaft. 4.11 course spline. SCRAPPED
Have some tiawan taillights for late model 40 (oval plugs). SOLD
Late model gas tank access cover in nice shape. $20 or BooKoo
Filler opening and door (aftermarket, was part of a quarter panel I didn't use). $10 or BooKoo sixer.
Canvas black bikini top made by ocdbeetle, never used but it's dusty. Brand New never used bikini mounting rails and hardware (including footman loops). SOLD
(1) 1" wheel spacers, willing to sell separately (work well for bigger spares on the stock carrier). $20
(2) 1.5" wheel spacers, $20 each. With lug nuts.
All the spacers are 6 lug and lug centric.
If you want to see any pics let me know. I am in SE Boise near Bown crossing.
At risk of "double posting", I've helped re-create some NLA springs for the FJ55 / pig community. Door handles and tail gate springs, details are here:
Still have oodles of them, should you need some let me know.
Calvin
WANTED
I’m starting to work through seats for my early ‘63 FJ45. I have a later driver’s seat frame that is in ok shape, have the back, will need a little bit of spring work that I could do but needs foam and covers. I’ve searched the club for local upholstery shops but it’s the passenger bench that is the most in need. I have the original frame which is solid, but it’s a more basic spring setup so would need spring buildup of sorts to match the driver‘s. Not sure if a later bench would match the bolt down locations hence the approach to rebuild what I have. Or....?
Looking for options or ideas. Pic of what I have. Thanks. Paul
WANTED
I'm not sure if this helps, but I've got one drivers seat in somewhat decent shape. I'm willing to part with.
@Keepinitstock definitely interested. Let me know what your looking for, I can obviously pick it up. Thanks!
  • Back
