CenTXFJ60
I'm pretty sure this is a 75 model. The vin is 4300 which shows to be the last month produced in 75. I may have it wrong, but that's what I found in a 40 stat sheet. My understanding (limited at best) is late 75's were unusual as there were some changes made going into 76 production.Windshield and barn doors are off a earlier model. 12/75 would be a 76 model that had disc brake axle on front. Would of had ambulance doors and wipers on the bottom of the windshield.
75 was the year between the new and old style top and doors. December makes yours newer, so tops from mid 75 to 83 should be what you're looking for. Doors finished out inside nicer, ambulance doors, and a few other little changes. good luck!question on the ambulance doors...since this one has the short rear doors, would I not need to source an early top with the hatch style rear? I figured I need side doors with panels etc. (later). Thanks.
That white one looks earlier though, as mentioned already.
if I'm reading this chart from CCOT correctly, would vin #4300 fall under a 75 model? Thanks.Model years almost always start before the calendar year. Believe 9./75 was the start of the 76 model year. Mine is a 10/75 and is a 76 model with disc brakes. The 75 model did not have disc brakes.
View attachment 1385559 if I'm reading this chart from CCOT correctly, would vin #4300 fall under a 75 model? Thanks.
February 1975. BTW, my '76 FJ40 VIN falls correctly in November 1975.View attachment 1385559 if I'm reading this chart from CCOT correctly, would vin #4300 fall under a 75 model? Thanks.
Then a 76 it isThat is a production date chart different then model year. The 2017 models have been available for a long time not just since January. If you went off production date you would be lucky to find a 2017 vehicle made in Japan in January.
The 75 is a cancer free SW truck built in December of 75. It has surface rust all over the skin. Needs new quarters and fenders (up to 1/2" Bondo).
