We aren't big fans of the puck style mounts often used for LS installs so in the most recent 60-series build we went ahead and designed a set of mounts to use the stock GM style motor mount (Delco 25828247). I have purchased similar mounts from Icon before but their design was lacking a few things I wanted and they've told me they're going to stop producing these. We made a few tweaks to the design to adjust the engine position and then added indexing holes so that we can quickly/easily set engines in position in the future.
These position the engine 7/8" offset to the driver's side and approximately 1" forward of the firewall at the rear of the passenger side cylinder head. They are compatible with truck and car AC compressors, stock Erod manifolds, Hooker cast iron manifolds and most likely anything else you'd want to use though we haven't tried them yet. Combined with the H3 swap oil pan (Delco 19212593) you should have adequate clearance for the front driveshaft.
We don't have an online store section on our web site yet but I'm sending off another order to the laser cutter for @Kleatus and ourselves. If anyone would like a set please let me know and we can hook you up with a pair.
******EDIT - Oct 2022 - We are still producing these in limited batches, after making a couple dozen we understand the costs much better and now are selling them for $395/pair. If you would like to purchase them please email "doug@wellsorted.com" and I will put you on the list for the next batch.
