Need help/advice on rear main seal
Wickenburg, Arizona
When I bought Miss Scarlet in 2017 I had my mechanic replace the rear main seal. It failed again in 2021 and had it replaced. It's failed again. The first time around we lived in Colorado. So, the garage queen sat undriven from early November until early April. Now she lives in Arizona a sits from mid May until late September while we flee the heat. My mechanic here in AZ says my problem is all the time sitting lets the seal dry out and fail which makes sense to me.
Are all replacement seals the same or is there a best one? I just hate to keep dumping $1,100 into it every three or four years for a rear main seal. I've even thought about selling her but just hate to and the wife is having a meltdown when I mention it.
are you using OEM seals?
You need to look for the speedy sleeve solution. I put a new toyota seal in my unit - yea it leaked just like my dad said it would. There are tiny groves wore on the sealing surface and it will never seal for long - speedy sleeve gives a new flat seal surface and will last a while. I have the rear main engine seal one need the one for the front inner axles.
I can (in the past) pull the engine/tranny/transfer in 3 hours by myself. Less than a day to pull it replace the seal and put it back - I don't make $1100 a day and can't afford to pay someone else that.
Not sure if rope seal was ever used on F or 2F. If so, I would consider for your use case. May need to have retaining pin in block or main cap to use.
They dont seal perfectly, but they dont just dry out and fail from setting either.
Is this where you would see those drips?? I’m getting a few.
I'm not sure if either replacement was OEM. Have not heard of speedy sleeve. Will check it out. Looks like I also have plug leak. They had a heck of a time finding the correct size.
The best plug gasket is a soft lead washer. Melt some pure lead (muzzleloader balls/bullet) in a big spoon from the thrift store/ yard sale with a propane torch. Never use that spoon for food!!!! Pour the molten lead on an old dry board/newspapers, you want disk as big as the flange on your plug and about 1/8 of inch thick. Center your plug on the disk and whack it with a hammer. Cut out the marked center so you have a form fitting crush washer that will last many cycles. Wash your hands well after handling lead, melt and cast outside, don't breath the fumes. Sheet lead will work if you have any.
UV oil dye, UV light, amber glasses and a borescope that works on your phone. $50 0r so. The have UV dye for coolant too in case you are looking at heater cores, water pumps - cross pipes....
How many miles are on it? I don't know if this effects F/2F engines, but worn main bearings can drop the crank enough to eat rear main seals on many engines. Tractor motor, I know...probably not applicable.
I'm the third owner. She has 112K documented miles.
+1 on the " are you sure it's the rear main seal?"
There is an oil galley pressed in welch plug on the back of the 2f block that is known to fail and send oil down to come out looking like a rear main seal leak.
Easy to overlook it if you don't know to look for it
What is the best way to see that plug?
Only way is to separate the bellhousing from the engine....
This is just the first result on dozens of threads about this issue. I just link it so you can see the plug I'm talking about. There are other threads that go in depth about how to seal it with the correct plug and or JB weld on top....
+2.
A valve cover gasket leak at the back where you can't see it can drop oil back there too.
also the side pushrod cover gasket can be a source
if the OP removes the bellhousing cover and looks inside that will help determine where the leak could be coming from
The rear main on my original 2F leaked from the factory for over 100K. I should have made the dealer replace it when I took it in for the first oil change.
When you had the main seal replaced the previous times did that stop all your leaks?
Yes, it took care of the leak at the rear main seal, but Cruisers like to pee on the garage floor. So, it is almost impossible to stop all leaks.
