Builds My R2.8 Cummins FJ40 (RJ40) daily driver build (2 Viewers)
Adding the clutch throwout arm/bearing. Ran into an issue when I realized I had a internal slave cylinder version of the NV4500. So I had to buy a new bearing retainer with a nose that the throwout bearing could ride on
Firewall and underside sandblasted and first stage of Lizardskin complete. Going to do the ceramic temperature isolation on Saturday. Frame with rebuilt axles and disc brakes front and rear. Front discs are Toyota. Rear are Cadillac El Dorado conversions. Rear diff has an ARB locker in it.
Gas tank and drive shafts. Obviously I need a new oil pan. I've ordered an aluminum one from Cummins. I'll do some mods to it when it arrives
What diameter is your front drive shaft???
I'm thinking of trying a 2" or smaller hoping that will clear the oil pan. I 'm pretty sure with the aluminum pan you have to relocate the dip stick from driver side to the passenger side where a lot of stuff is in the way and not much to attach to.
I think it's about 2.5" maybe 3"?
Also! The oil pan I got has dip stick receivers on BOTH SIDES. I just looked at Sean's and he's got both spots for the stick.. They must have changed the design since the last casting.. I think. I'll check tonight
If you need pics of my oil pan or exact measurements on the drive shaft let me know and I'll send them over
Yes if you have pics please send them. Please let me know if the dip stick can remain on drivers side and I order mine. I can always have the aluminum pan modified and TIG welded to clear driveshaft if needed. Sean thought his aluminum pan would clear driveshaft without modifying. Let me know what you find out.
Thanks
Thanks
Hey man,
I just emailed you some pics. Hopefully I'll be fitting the oil pan soon so I can let you know if the dip stick works on both sides. If anyone else needs pics of the aluminum oil pan let me know
Why not just post the pics in this thread?
Hey man,
Please let me know aboiut that oil pan as soon as you can, Cummins is terrible about running out of product. Right now the dipstick for the aluminum pans is "Out of Stock".
Thanks
Hey man,
Thanks I couldn't access pics you emailed me, glad you posted here. Yeah looks like pan will provide dip stick install on driver side. Gonna order mine now before their out AGAIN.
Yeah, I've been thinking about one but I'd like to get a little further in the build to see how close the composite pan will be. Either way, I'll have to make a skid plate.
"Ran into an issue when I realized I had a internal slave cylinder version of the NV4500. So I had to buy a new bearing retainer with a nose that the throwout bearing could ride on"
So you have a 96+ GM NV4500. What bearing retainer are you now using? What input shaft are you now using?
