Anybody know a gasket that would get close? Glass is 14" x "32 approx.
Thanks
Thanks
Those hardtops are cool! I never saw one first hand until @devo picked me up at the Denver airport in his rig four years ago. When you find the answer to your question, please post up so that others with this top can benefit.Anybody know a gasket that would get close? Glass is 14" x "32 approx.
Thanks
Does it match up pretty close when you hold it up to the glass? What's part #?I bought one from City Racer but have not installed it.
My apologies, I did not realize the OP was discussing the MPR hard top.To my knowledge CR doesn’t have any direct part replacements for a MPR hard top!
The MPR was specific to the Colombian 40 series and the window gaskets/ seals are not the same as on an OEM hard top.
Yes, but if it's similar and hopefully just a little bit bigger maybe i can cut it and make it work.To my knowledge CR doesn’t have any direct part replacements for a MPR hard top!
Theoretically, if the seal was cut somewhat long and squeezed in it wouldn't later open up. That said I'm not an expert glass layer and I've only got what I've read to go by. I'm thinking an extra 1-1.5" so that the seal is as tight as possible.Okay @Storm Ranch this what my back door glass seal looks like. It is S shape with the small channel 2mm fits the fiber glass door and the large 4mm channel fits the glass…..
this is the old gasket in the photos
Wish I could remember who I ordered it from?
This would be correct. Straight cut for the joint. Urethane windshield adhesive can be used on the seam after install.Theoretically, if the seal was cut somewhat long and squeezed in it wouldn't later open up. That said I'm not an expert glass layer and I've only got what I've read to go by. I'm thinking an extra 1-1.5" so that the seal is as tight as possible.
