Motor mounts and brackets?
South Central Oregon
I will be converting my 1970 FJ40 back to a straight 6 F.5 from the Chevy 327 that's currently in it. I do not the original motor mounts, any tips on which company sells good mounts and brackets, both motor and frame? I've checked SOR but was wondering if any other company has a quality product that I could look into? Any help and advice is much appreciated.
Rock Auto has motor mounts for 60’s, not sure about 40’s.
I had to buy motor mounts recently on eBay, and that worked fine for me
@ToyotaMatt do you have anything?
For the used steel parts, Classic Cruisers, Cruiser Corps.
For the soft parts, use the updated style, post '76, up front. On the back, I used some SOR hockey pucks and Grade 5 1/2-20 Hillman bolts and drilled it for a cotter pin - it was close to the original M13 fine pitch in OD and thread root diameter.
i have exactly only 2 NOS ones here .........
stand by for pics
comes with ALL new OEM install hardware too bolts nuts washers japan goodness !
Hey fellows and female owner operators too in fact !
Sorry I’m late busy Tuesday night here at the LAB
I have 2 Nos 12361-60022. Mounts
Both include all new oem
Mounting hardware of course ..
They have been sleeping in my outbuilding #3 fir long time
Perfect condition ,
Well cosmetically I can’t say …. 🤔
Mechanically perfecto ! :D
words of wisdom here :
CHINA KNOCK offs clone are rampant on ebay don't even think about getting your feelings hurt there doing something silly to save only :
stand by for pics
stand by for pics
I'm not sure what NOS means? Is it new on shelf? I checked your website, which is very well made but was able to find mounts and brackets.
Hello Mark, how much for all the parts needed to mount a F 1.5 in a 1970 FJ40?
You will probably need to phone him if you want a quick response.
IIRCC the issue with newer isolators in older rigs is the boss in the new isolator. the older frame mount didn't have a recess for the boss to go into.
A very good point Paul. Almost never gets discussed. Especially in the aftermarket, mfgrs often vary on the boss height. Some fit in the recess in the ears just fine; others need to be ground down.
