FF 14 bolt. Less labor/time intensive than a Toyota. If you're thinking about doing it, and/or planning on it down the road, you'd be wise to build the 14 bolt now versus spending the money twice.
I was wondering how long it would take before you posted up about the D300. Nice scores.
I agree with you, which is why I'm going to run what I've got for now, then make a final decision later down the road.
Thanks!!
If you go the 14 bolt route save yourself some frustration and get a shave kit for it. I get hung up on mine even after shaving the bottom as much as I thought was safe.... Pretty indestructible axle though if you can get past how low it hangs.
D
If / When I install a 14 bolt, I will absolutely make sure to use Ballistic's shave kit. No ground clearance without that!
Thanks D!
For a 4BT I think you would be ok running the FZJ80 axle. Also the diff on the FZJ80 axles is almost centered to begin with. I would just swap your internals over.
Keeping it stock would be an easy swap, I have a leaf converted FZJ80 axle laying around. If you were planning on taking a trip up to NY anytime soon I would save it for you.
That way if you find yourself blowing through axles you wouldn't have tons of time invested and the 14 bolt swap could commence.
A 14 Bolt is a way overkill axle, I doubt even my 6BT will hurt it.
Ground clearance is awful on them though, I need to measure how much I have running my 43's.
This is a brilliant idea. I need to go home and measure what the offset is of the FZJ80 axle, but it should work. That'll be the least $ invested and will give me more time to make a final decision as to what rear axle to run.
You are the MAN!!
i like the toyota axle option. you keep it toyota between the front and rear axle and you can use that elocker you have. I think the time and effort involved to make it centered and the width you want is all part of the addiction of what we/you are doing. And, its unique....
the C&C 14 bolt is huge! its got very large drum brakes that would need to be removed for discs. Also, the 14 bolt will be 8 lugs, so new wheels?
If I ran a 14 bolt axle, I'd shave it and run some machined C&C hubs to get 61" WMS-WMS, with the Toyota 6 bolt hub pattern. This is a bit more expensive, but I wouldn't have to change out both sets of wheels and tires.
It'd drive me nuts if I had 6 lug up front and 8 lug out back
I'm going to run the FZJ80 rear axle at first, then see if it blows up. If not, then one of two things will happen:
1. It'll stay how it is
2. We'll build a truly centered FZJ80 axle housing
So this is THE problem. You need to consider an 8 lug up front or a custom 6 bolt hub in the rear. You need to have the same pattern front and rear or else carry 2 spares. That's a pain.
Personally, I think it would be better long term to go to a D60 up front to match your 14 bolt rear. Then you have an overkill axle and can forget about breakage. Until you are ready to do that, probably best to stay with Toyota until you break them.
Always with succinct and logical advice, thank you Drew
You have a good point, why run the 'ton rear with a weaker front. Might as well upgrade to 'tons front and rear, all at the same time, and I agree. I'm not ready to completely let go of my Toyota drivetrain, so I'll stay with the Toy axles.
Thank you sir!
Pretty darn good day! I mean, real good. How much was that re-man head?
Yes sir!! I was not completely honest with you in my post above. I dropped off my 4BT head at the machine shop a couple of weeks ago. I had them hot tank, mangaflux and deck the head. They then replaced the valve springs with 60# ones ( supplied by me ), ground and polished all of the valves and then reassembled everything.
So, the $150 was for all the machine work, new valve seals and repairing my broken manifold bolt.
I'd have to say you'll probably not have an issue with the 80 axles and there are stronger axle available but that if you put the same effort into the 14 bolt you won't have to think about your rear axle again. 37s are a good size but I'd shave the 14B too if you are keeping that tire size. As for the rear disc brake brackets from Ruffstuff for a C&C 14B I cannot recommend them due to my last incident with them. Short story is I have to fix some collateral damage due to one of the brackets letting go.
Since I've got the 80 axle, I'm going to run it. Most people think that it'll be fine, so we shall see. I've got all the parts already, might as well use them, right?
That accident you mentioned in your build was due to the caliper brackets letting go?!?!?
That's a scary situation!!! I remember you posting up a while back that you saw some stress cracks on the brackets, but I thought that you were able to repair them. That's not something anyone wants to deal with. Did you have the weld-on brackets?
Thanks for the help everyone!! Moonshine is truly the culmination of the 'Mud brain trust
