Mobil `1 Synthetic In Tcase?? (2 Viewers)
San Diego
Website
youtube.com
anyone running this?
its time for me to drain and fill and was curious about this? i usually run mobil 1 syn in everything
thanks
Yup.
M1 75W-90 in T-Case and both diffs.
Me too, me too! :) (and probably a hundred others on here).
Mobil 1 75W-90 in both diffs and the T-case.
Just realized all three answers came out of Texas. I guess it is too miserable outside so we are all inside at the 'puters :crybaby:
Mine is different, Amspoil 75W90 in both diffs and t-case.
Amspoil.....is that really old, rotten Amsoil? :grinpimp:
I run the s***ty stuff--Coastal 80w90 and change it out every oil change--3K-4K. Same with the diffs.
It does fine.
I buy it in 5 gal buckets for about $24.
Is it worth it? Probably. Is it worth the cash? Probably not.
:flipoff2:
-o-
Beno man...unless you're dunking hot diffs into water, you really can run that Coastal stuff longer than that :)
That stuff must look virgin when you drain it?
Mobil 1 syn in pumpkins and t-case
M1 75W-90 diffs and transfercase.
Amsoil...diffs...tcase...ccase...soon tranny.
No SYNTHECTIC Here does not make SENSE cost vs benifit
I was running Mobil 1, but now I run Redline synthetic.
Mobil 1 will work fine though.
