When I'm driving my clutch release point seems to move around occasionally. This most often occurs on first start of the day, but not always. First thought was a bleed problem since pumping the clutch fixes it, but bleeding it doesn't seem to help. My truck has gone through three engine iterations (74 1.5F, 75 2F, and 87 2F) so is a bit of a mashup of parts. The clutch, fork and slave are new (and for a '75+ truck). But the adjustment nut on the end of the rod is all the way out. I've got the pre '75 spring, etc on the slave. The throwout bearing is definitely not engaged, so I don't think its a mis-adjustment. The clutch pedal is adjusted to factory specs. 95% of the time everything works perfect and releases where it should. So my question is if my slave is too far away from the clutch fork? Should I buy a '75+ rear motor mount and slave return spring? Do those move the slave closer to the fork? Maybe the slave rod isn't returning consistently enough sometimes to get a full stroke? (and I see my slave has rotated a bit on me, so I'll fix that)
Thanks.
Thanks.
