- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
Clear photo of what part of a 76 clutch setup?
Wouldn’t it be a lot simpler to thread some round stock and make a longer pushrod to work with that slave than pulling the trans to swap the fork over, move the slave, and fab a hydraulic line to run across the firewall?
That’s a great photo. Thanks!
I went cheapo on the washer. But it slid right in and worked right off the bat with good pressure. It comes with a flimsy mount, but I still had the OEM one. Either would have worked fine. I was pretty surprised it worked as well as it did.
Windshield Washer Tank Pump for Toyota Land Cruiser FJ40 FJ45 FJ50 FJ55 FJ60 HJ | eBay
Find many great new & used options and get the best deals for Windshield Washer Tank Pump for Toyota Land Cruiser FJ40 FJ45 FJ50 FJ55 FJ60 HJ at the best online prices at eBay! Free shipping for many products!www.ebay.com
If you only need to slide the tranny back a 1/4", couldn't you just loosen the trans to bell housing bolts about that much, and not have to use the dowels? My F engine w/ 3 speed has 13 mm bolts, so dowels are harder to find...If a pivot ball is to be added or removed the trans must be slid back about 1/4" to allow the pivot ball BOLT to be completely removed or inserted due to the length of the bolt. You can free the bolt from the pivot ball, but there isn't enough room to back the bolt out. If, for some reason, you had a pivot ball on the "other side" from where the fork is there is no need to slide the trans. At least not in my case (75 bell housing). Simply move the fork over to the other pivot.
Does that make sense?
Edit: Sliding the trans was very easy, but I already had made a couple dowels and the entire setup hadn't be together long enough to "fuse". Just a screw driver sufficed.
