Mike's 1978 FJ40 Build (3 Viewers)
I think I would get the alternator/wiring checked out. My AMP gauge always seems to run in the negative when under load. I guess so long as it bounces around when I hit the blinkers or A/C I assume all is working.
That's something to consider possible faulty wiring. Thanks for your thoughts Ernest!
A very perplexing day to say the least,Here's the latest issue. So I decided to help out a friend by sympathetically conducting similar tests on my VR and new alternator , so here are my test findings.
VR testing Pic 1 engine off Lights Off ~ Batt Voltage
full
Pic 2
full
Pic 3
full
VR testing Pic 4 engine ON at 1800 RPM Lights On
full
Pic 5
full
Pic 6
full
VR testing 7 engine on at 1000 RPM Lights On
full
Pic 8 VR adjusted several times as per the FSM with similar results no appreciable charging
full
VR test pic 10 after several adjustments no appreciable charging
full
pic 11
full
Pic 12 Brand New Voltage Regulator from O'Reilly's purchased today
full
installed
full
Pic 14 New VR testing 1000 RPM Lights On voltage fluctuation 11.72 V - 11.73 V
full
pic 15
full
I didn't know that this problem existed with my VR and new alternator, based on the above results it's safe to assume that my charging system is faulty, any advice?
This also explains as to why my previous Optima battery died a cruel death several months ago.
Does it charge at 2k rpm, Mike?
Hey Danny, no unfortunately no charging at +/- 2000 rpm the reading was 11.73 v, at 1000 rpm it was higher at 11.82 v, what's strange is that the voltage readings were almost the same even with a brand new VR. Which leads me to believe that it's either a bad alternator or faulty wiring. I have a brand new belt on the alt and it's adjusted real tight with 1/2 inch deflection, so there's no slipping. I'm perplexed.
Have you read thru Rudi's (@bj40green ) VR thread, that I posted up a ways, in Jeff's thread? Great stuff!!
It really sounds like you need to have your alternator tested. Also, if you drive to an auto parts, they will run diagnostics on your electrical system.
I replaced my VR and had alt rebuilt about 6 months ago; wonder what my reading would be?? Now you have me thinking Mike, how old is your alternator?
Yes I've read @bj40green 's thread excellent information! Rudi is the best! I'll be testing the alternator soon. Thanks!
Tom, My alternator is brand new. Have you tested yours?
Did you test the power lead at the back of the alternator to see if there is a difference in voltage compared to at the battery? Good Luck. Geoff.
Thanks Geof I will try your testing method soon.
I received a care package from Onur @beno with also a few extra gifts! Thanks Onur!!
Here are a few pics:
1. TEQ radiator cap
1. TEQ gas cap
1. Windshield wiper motor housing gasket
A bonus Toyota Genuine Parts beanie!
And two Land Cruiser Parts and Consulting stickers!
full
Installed the TEQ radiator cap ~ I'm very happy with the new look!
full
Installed the new TEQ gas cap, the old cap was leaking and as such was complaining by hissing and groaning while the engine running.
full
I also purchased a new gasket for the windshield wiper motor housing, unfortunately was not able to install it today but will real soon.
Nice fresh produce there Mike! Is that the correct gas cap for a '78? I know it is right for a '76, not sure about a '78
If @beno says it's for a '78 I do not question his authority and knowledge on OEM Toyota parts.
He may be wrong...................
Prior to re-installing the roof I used this automotive sealant product to level off all uneven areas that the roof seal rests on to create a water proof seal. This product is soft and will not harden, I've had this tube from previous projects and it's about 20 years old and still very pliable.
full
These are the ares that needed leveling
full
Applied sealant to cover the uneven areas
full
Pumped sealant over uneven door jam
full
Then leveled it off
full
Ready to install the roof
full
Re-installing the roof
Installing the little rubber bits for a leak free install
full
I applied some body sealer under and around this piece to ensure a leak free roof
full
Next was the rear door jam rubber seal (self sticking)
full
full
Front door seal it interlocks with door header trim piece, fits like a glove
full
pic of other side
full
installed
full
Next installed the front door seal
full
glued in place
full
And the roof is now complete.:banana::banana:
Question, did you use any adhesive for your rubber trim strips that interact with door header piece?
I finally received the heater rebuild kit from Bend Oregon.
Here are the after pics, saving you all from all the gory details of pressure washing the core and disinfecting the housing etc.
I finally installed the heater, in the process I cleaned up the radio bowl of spaghetti wires installed by the PO what a mess as you can see
Now I can fill the engine with antifreeze.
How were you able to get the heating duct back over the end with all that foam on it? mines almost tight with no foam. I was thinking of silicone to seal it up.
