without reading the posts above
bench testing with shutters, bulbs, and ballasts with a standalone source doesn't exactly mimic the car environment. Testing a shutter with two wires and a 9 volt is a good exercise but once in the car that's all it was.
The high beam splitter connection at the car end and the connection at the shutter are culprits. Ignition cords are something I don't trust either.
surge has been proven on the 35 XBs. Any relay harness sent out by me has been tested, made to withstand 55wattX2+surge, I think 10 feet travel and <14vdc.
The only thing that would happen is the 15amp fuse blows on the BAT+ leg.
Splitters on ebay and amazon cost about 5 cents each to buy in bulk, they are all the same.
If I made a pair of splitters it costs about 45$.
Ignition cords are dirt cheap on ali. The best connection to theHID element are the round pink ones on ali, or ebay if you find them. AMP only though.
They have the best socket connection to the element.
The fancy square aluminum flashing, anything with cheap locking tabs at the element will be garbage and cost too much.
Making those is out of my league. There can easily be a loose connection at the locking tab, vibration etc.
You need clean connections to the ballasts, the ignition cord at the ballast, and the HID element.
The battery, relay, trigger and output leads are easy to test.
after reading the above posts.
thex2, did you take apart the relay harness. Are the grounds and output to ballast leads joined, ground good I assume since what you said above.
Do you want to potentially put 140+- watts through that joined connection on a sub 18gauge wire? I started out with a ten amp fuse in relay harnesses, fine for 35 watt ballasts. Mapped the wire and went with 15 amp for 55watt downward compatible.
A mod deleted my HID relay thread, I don't know why. Probably because I quit paying the 10 dollar a month fee for the red ribbon. There was pretty good info there.
if you do mess around and use questionable relays and wire for long enough I think the evidence is clear that ballasts suffer.
FLickering the hid element a ton of times is bad also. Those extra sells- capacitors people sell do not help the LC LX.
I just looked at trs site again , the have the pink 90 degree cords for 17$ pair. Worth it for shipping time, but they're 2$ or so from china.
Do not buy the DIY relay they sell. IT's a copy of delphi components which can be bought for slightly more that they sell, maybe 10 dollars, terminals, housing hella, song chuan relay etc.
IF the input to ballast is good at the non lighted element (with other side lighted) then I'd assume ballast output- ignition cord/AMP junction. - then element.
IF all that's good I'd go backwards toward the battery, split the sheathing off the relay harness and have a look, swap relays, get a better ground, ground your ballasts individually, swap ballasts/cords around see if the fault follows.
Maybe I wrote too much. Don't mean to be master of the obvious to anyone explicitly. There's a lot of that info gone from the relay thread.
this is the only place I'd buy a relay kit from from that I know of, won't be to custom length, But I know these people. My personal stuff is packed up to move, other wise I could send you whatever. 170$ is ok money, not great. People would be well over that if they bought individual components to make one.
all that to say, if you don't start at the beginning with reliable power supply and grounds, everything else won't matter.
ceautoelectricsupply.com/h4-sealed-beam-headlight-relay-kits/
