Installed Morimoto Mini H1 7.0 projectors using Lou's brackets into my '05 LX this afternoon. Very straightforward process and everything bolted up with no major fabrication required. Took me 1.5 hours for the first light, 1 hour for the second. I used Morimoto Retro Rubber butyl and TRS's MoriHolder bulb holders, both highly recommended and very inexpensive.
I used a heat gun for the first lens as I was worried I'd destroy my Lamin-X film in the oven. It worked. The second one I put in the oven at 200F for 20 mins and the film was fine, much easier to pry off lens.
I'm going to create a brief DIY for headlamp removal.
Lighting performance is literally a night & day difference from OEM halogens. I used a 9005 splitter from TRS to activate the high beam solenoid.
My advice is just do it, you'll regret not doing it sooner. Buy Lou's brackets and the above noted accessories from TRS to do it right and make it easy.
