Local For Sale/Wanted Section! (10 Viewers)
Out of curiosity - are there any differences or improvements in the 4-speeds over the years? I’d never heard of any. Either way, my truck is a 75 - so a 75 4-speed should fit right in.
There was a change in length of the four speeds somewhere in the mid-80s that affected the 60 series.
April 85...but i dont think the case changed.
There is a spacer between the trans and xfer.
Output to tcase spline count changed, as did gear spacing and they added a cross member boss in 1980.
Did the change in spline count all correlate to the switch to a split-case?
Either way, sounds like one of Brian's will work. Brian I'll send you a PM.
Having been on exactly 1 wheeling trip and mercilessly abusing my clutch - I now understand the need for lower gear ratios, but I'll probably rebuild and install a 4-speed until some point 10 years from now when I can afford a H55 and 4:1 split case and feel like completely redoing my driveline again...
Plus, a 28:1 ratio was probably not nearly the problem I felt like it was - more likely fault lies with the noob behind the wheel ;-)
Best advice for new wheelers of land cruisers is stay off the clutch. Let the torque from the motor keep you chugging along. When it starts to stall give it a little burp of throttle and it’ll keep on chugging.
Anyone need a free tire? I used this as a spare a couple of trucks ago... standard Land cruiser size in a 275/70/16. Its the oem Michelin LTX m/s with probably 1/3 of the tread left. It has minimal dry rot and manufacture date of 08.
Any LX470 owners need a new (used) set of springs? These were removed from my 2000 Lexus LX470 at about 150k miles. They are in fine shape... went with a set of Kings to replace...
FREE
The garage clean out continues... I have a set of (4) hubcaps... I got these years ago when I was running a set of 16” Tundra steelies... free
For sale
4 -33x12.50r15 procomp mud terrain on steel rims.
Tires have about 92% tread left (17/32).One wheeling trip and about 1k miles around town.
$600 OBO- delivered to CMCC
I know. Thought I’d check to see if anyone had some laying around before calling @beno to order new ones.
Anyone interested in a super nice cruiser? This is a 2003 Yamaha Vstar Classic 1100 with less than 9k miles. Looking for $2500...
I can't take it, but I will say, these are hands down the best handling/riding of all the metric cruisers. They corner beautifully and inspire conference in ones riding.
Got any farkles for it Rob, bags, seats, ect?
This was a hard learned lesson, probably knocked a few thousand miles off my clutch!
Wanted: 5x 40-series OEM steel rims and hubcaps.
I am running the new reproduction wheels in 16" from from City Racer. The main reason I went this (more expensive) route is that there are a lot of additional tires available in 16" (including taller skinny options) you can no longer get in 15." OEM hubcaps mount right up. Pricey though...
