Builds Land Crusher Build Thread - V2
Tires arrived, they’ll be mounted on Monday:
These shocks are HUGE:
Just had my BP-51s installed. Sooo much nicer than non reservoir shocks
What settings are you running for compression and rebound? I need to get them dialed in.
It’s super hot and I’m a wimp about it, so moving slow on this install. But most of the front is done. Just need to do the caster plates.
Hold tight. I'll take a pic
I don't have a lot of miles , and I did tweak them a bit, but it's good for what I drive. 3fe and a ARB bumper. Light in the back. Hope this helps
Big pile of wheels all ceramic coated:
This adams wheel ceramic coating is extra thick relative to the stuff that goes on paint but applies the same. It also has a UV component that will glow under black light so you can verify you applied it to all of the surfaces and then see how it's holding up over time. Pretty neat stuff. I have the kit to do the paint as well, but that may not happen until the weather cools off. Going to do @ncavi10 's new wheels that are coming for his 100 this weekend :grinpimp:
Rear suspension is just about finished:
Next up is master cylinder and booster replacement, tie up the LSPV while I decide what to do with it (wilwood proportioning valve), and then bleed the brakes. My calipers aren't leaking and the pistons are in good shape, so I won't be rebuilding them this time around.
Got my LandShark reef 2.0 drawer carpeted and installed today. Used the econo caret from Lowes and Loctite 300 heavy duty adhesive.
I have the filler piece to put on and need to shim a tad so it sits level. Having built a few sets of my own drawers for friends 100’s, these are killer and way easier. Overall pretty happy with these!
Brakes are bled! Yet to test out How the new booster, master, and stainless lines feel. Should have the caster correction plate installed mañana.
If you haven’t used one of these Motive Bleeders, definitely give it a try. This thing was real clean and simple to use, great for a solo bleed.
This is the Motive universal that I added an amazon bleeder cap.
