Is anyone using this bulb ? Would this be the bulb to use on a 1997 lx450 ? the 9006 .https://www.amazon.com/dp/B07JF5LTR...d_r=d89fe23c-19c1-11e9-a5cf-b183fdaf236c&th=1
Those look like a waste of $.
I just bought a set of Wagner Headlight Bulbs 9011 for the low beam for $20. 9011 is an upgrade to the #9006.
PDoyle where did you get a set of 2 bulbs for 20.00 ? Will you give me a link ?
I found them on Ebay, made an offer paid about $20.
I think they are junk I went with sylvania bright white are way better
Thanks At rockauto they are 8.40 per bulb so for 2 of them including shipping the total is 21.79 . That sound good to me .Yes, this is the way to go. Buy them on RockAuto.
Are you saying that the same 9011 will work in both high and low beam ? If so thats good to know . I like the idea of both high and low bulbs being the same bulb . Just one extra bulb in the truck would be good for all 4 lights . If I fit the 9011 for the low beam do I have to do any other adjustments to make it fit the high beams ?Yep, good bulbs and inexpensive enough to buy a set of 'spares'. Go ahead and modify the bases and have them ready to go when the others finally burn out. I run them in both high and low beam locations. Still running my Toshiba units from 10 years ago. I have spares in the vehicle for when I need them.
Look at this led bulb . It looks like they are making the light go where it should go now. I know you typed that 4 years ago ,maybe things have changed with the led bulbs . https://www.amazon.com/dp/B07JF5LTR...d_r=d89fe23c-19c1-11e9-a5cf-b183fdaf236c&th=1Theory is the key word...It's not even close. I tried "good" focusable LEDs in my low beams. They are not even usable in my opinion. There is a lot more light but it's everywhere except where you need it. I could barely see the pavement but the street signs and trees were lit up like daytime with the best beam pattern I could get out of them. I was able to get some semblance of a horizontal cutoff after some time adjusting them but the light source is just too far off from where the factory reflector needs it to be. I took them out after a few nights and got HIRs. WAY less light but I can see much better than the LEDs.
Interested in this as well.Are you saying that the same 9011 will work in both high and low beam ? If so thats good to know . I like the idea of both high and low bulbs being the same bulb . Just one extra bulb in the truck would be good for all 4 lights . If I fit the 9011 for the low beam do I have to do any other adjustments to make it fit the high beams ?
Got 4 Wagner 9011 to run in Hi/low in the mail. RockAuto was about $45 for all 4. I hope I will be able to see at night...kinda importantJust get the Wagner 9011's , they are the best bang for the buck upgrade you are going to get. They are actually a Philips of Germany bulb inside Wagner packaging. @shocktower are you referring to the LED lights posted up above or the actual Philips HIR's? I've been through several sets of 9011's over the last 7 years and they have always been excellent.
I just ordered a set of 9012. I'll update once I receive them.
Edit: clearly I did not read the whole thread... maybe i should have ordered the 9011's. I used the link on the first page to purchase 2 for 38.00. $46 after shipping
Best
